piBeacon Error after upgrade to 2022.160.16
Wed Dec 14, 2022 1:50 pm
Sam offline
I get an error after upgrade piBeacon-plugin to 2022.160.16, Indigo version 2022.1.2.
piBeacon Error 'local variable 'xx' referenced before assignment'
setGroupStatus @line 1739: 'triggerGroup[xx]["oneHome"] = False'
I only use the plugin for sensors. The Pi:s location is 21-26.
Any ideas?
Thanks in advance.. /Sam
Fri Dec 30, 2022 5:01 am
johnpolasek offline
Re: piBeacon Error after upgrade to 2022.160.16
I just noticed that I am getting it as well (almost never check the log)... it does not seem to be affecting the execution though.
Fri Jan 20, 2023 1:21 pm
johnpolasek offline
Finally got a chance to look at the actual code; the relevant portions (still present in 2022.160.19) is and the failure occurs in the elif apparently for nonBLE devices that are not sensors:
            if dev.deviceTypeId  in ["rPI","rPI-Sensor","beacon","BLEconnect"]:
               for xx in _GlobalConst_groupListDef:
                  if xx == "SENSOR": continue
                  if dev.states["note"].lower().find(xx.lower()) >-1:
                     if dev.states["status"] == "up":
                        self.groupStatusList[xx]["nHome"]     +=1
                        triggerGroup[xx]["oneHome"]               = True
                        self.groupStatusList[xx]["nAway"]     +=1
                  okList.append("{}".format(dev.id))
            elif dev.pluginProps.get("isSensorDevice",False):
                        dt = (datetime.datetime.now() - dev.lastChanged).seconds
                        up = dt < self.awayWhenNochangeInSeconds
                        #self.indiLOG.log(10,"setGroupStatus1 {}, dt:{} , up:{}, self.awayWhenNochangeInSeconds:{}".format(dev.name, dt, up, self.awayWhenNochangeInSeconds))
                        if up:
                           self.groupStatusList["SENSOR"]["nHome"]     +=1
                           self.groupStatusList["SENSOR"]["nAway"]     +=1
and since I don't know what kind of non sensor, non BLE devices would have "devlastChanged" states, I can't be sure whether the entire elif should be removed OR another
should be added just under the
and I don't want to break anything by tweaking the code.
