'name 'cmd0' is not defined'
Posted: Fri Aug 19, 2022 2:03 pm
I swear I had three pibeacons workign properly about 7 years ago, and now for the life of me I can't get one up with your pre-configured image. The pi is detected by the plugin, but when the plugin tells it to reboot, or before that, the log below.
Anybody who can help me, very appreciated. I already deleted the old line from nano /Users/USERNAME/.ssh/known_hosts on my mac
- Code: Select all
2022-08-19 15:47:14 .. startup(self): setting variables, debug .. finished
2022-08-19 15:47:14 entering init runConcurrentThread
2022-08-19 15:47:14 MAP2Vendor initializing with python v:3
2022-08-19 15:47:14 MAP2Vendor initializing finished, read from mac2Vendor.json file
2022-08-19 15:47:14 setting BeaconsCheck to off (no up-->down) for 50 secs requested by: initConcurrentThread
2022-08-19 15:47:14 .. starting tcpip socket listener, for RPI data, might take some time, using: ip#=192.168.1.12 ; port#= 12087
2022-08-19 15:47:14 .. startTcpipListening lsof output: -
2022-08-19 15:47:14 .. startTcpipListening try#: 0 time elapsed: 0.1 secs; resp: [Errno 48] Address already in use
2022-08-19 15:47:22 .. startTcpipListening try#: 1 time elapsed: 7.2 secs; resp: [Errno 48] Address already in use
2022-08-19 15:47:29 .. startTcpipListening try#: 2 time elapsed: 14.4 secs; resp: [Errno 48] Address already in use
2022-08-19 15:47:36 .. startTcpipListening try#: 3 time elapsed: 21.5 secs; setting re-use = 1; timout = 5
2022-08-19 15:47:36 .. startTcpipListening /usr/sbin/lsof -i tcp:12087 output:
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
IndigoPlu 72922 MACUSERNAME 8u IPv4 0x19874972d6460db 0t0 TCP 192.168.1.12:12087 (LISTEN)
2022-08-19 15:47:36 .. startTcpipListening tcpip socket listener running; thread-ID: Thread-2 (serve_forever)
2022-08-19 15:47:36 setting BeaconsCheck to off (no up-->down) for 40 secs requested by: initConcurrentThread
2022-08-19 15:47:36 .. checking sensors
2022-08-19 15:47:36 .. checking BLEconnect
2022-08-19 15:47:36 .. checking beacons
2022-08-19 15:47:36 updating pi server files called from:
2022-08-19 15:47:36 .. checking for new py programs for RPIs; currentV:2022.146.6, newV:2022.146.6
2022-08-19 15:47:36 checkForUpdates updateNeeded findAnyTaskPi: True
2022-08-19 15:47:36 FTP adding to update list {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 0, 'exeTime': 1660938456.432273}
2022-08-19 15:47:36 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 0, 'exeTime': 1660938456.432273}
2022-08-19 15:47:36 enter sendFilesToPiFTP #0 fileToSend:
2022-08-19 15:47:36 SSH adding to update list {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 0, 'exeTime': 1660938456.729229}
2022-08-19 15:47:36 setting BeaconsCheck to off (no up-->down) for 50 secs requested by: initConcurrentThread
2022-08-19 15:47:36 .. initialized, starting loop
2022-08-19 15:47:37 sbin/ping -c 1 -W 40 -o 192.168.1.118 return-code: 2
2022-08-19 15:47:39 /sbin/ping -c 1 -W 400 -o 192.168.1.118 ret-code:
2022-08-19 15:47:39 pi server # 0 PI# 192.168.1.118 not online - does not answer ping - , skipping update
2022-08-19 15:47:39 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 0, 'exeTime': 1660938456.729229}
2022-08-19 15:47:40 sbin/ping -c 1 -W 40 -o 192.168.1.118 return-code: 2
2022-08-19 15:47:41 /sbin/ping -c 1 -W 400 -o 192.168.1.118 ret-code:
2022-08-19 15:47:41 rebootSSH.exp Pi# 0
/usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/rebootSSH.exp' pi MYPASSWORD assword 192.168.1.118 15 &
2022-08-19 15:47:41.035 ERROR Plugin.exceptionHandler 'name 'cmd0' is not defined'
execSshToRPI @line 18578: 'ret, err = self.readPopen(cmd0)'
2022-08-19 15:47:42 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 1, 'exeTime': 1660938464.586887}
2022-08-19 15:47:42 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 1, 'exeTime': 1660938466.036045}
2022-08-19 15:47:43 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 1, 'exeTime': 1660938464.586887}
2022-08-19 15:47:43 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 1, 'exeTime': 1660938466.036045}
2022-08-19 15:47:44 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 1, 'exeTime': 1660938464.586887}
2022-08-19 15:47:44 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 1, 'exeTime': 1660938466.036045}
2022-08-19 15:47:45 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'updateParamsFTP.exp', 'endAction': 'repeatUntilFinished', 'type': 'ftp', 'tries': 1, 'exeTime': 1660938464.586887}
2022-08-19 15:47:45 enter sendFilesToPiFTP #0 fileToSend:
2022-08-19 15:47:45 sbin/ping -c 1 -W 40 -o 192.168.1.118 return-code: 0
2022-08-19 15:47:45 updating pi server config for # 0 executing
/usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp' pi MYPASSWORD assword 192.168.1.118 0 '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.piBeacon/' '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/pi' 15
2022-08-19 15:47:50 UpdateRPI seems to have been completed for pi# 0 updateParamsFTP.exp
2022-08-19 15:47:50 rpiUpdateThread executing {'pi': '0', 'fileToSend': 'rebootSSH.exp', 'endAction': 'repeatUntilFinished', 'type': 'ssh', 'tries': 1, 'exeTime': 1660938466.036045}
2022-08-19 15:47:50 sbin/ping -c 1 -W 40 -o 192.168.1.118 return-code: 0
2022-08-19 15:47:50 rebootSSH.exp Pi# 0
2022-08-19 15:47:50.731 ERROR Plugin.exceptionHandler 'name 'cmd0' is not defined'
