Pibeacon keeps go down
Thu Jun 06, 2019 11:52 pm
koburg offline
one of my pibeacon keeps go down.
yesterday I took a brand new 16gb sd card and loaded the latest img to and did the send all files and reboot.
It looked like it did work but today the pibeacon have the same error keeps getting offline it is connected thru wifi ubnt.
but only 2 meters from the wifi.
Fri Jun 07, 2019 4:57 am
Re: Pibeacon keeps go down
With going down you mean shutdown?
Can you ping the rpi?
Do the following test
In terminal
ssh pi@..
tail -F /var/log/piBeacon.log
And wait until it goes down
What are the last lines?
Tue Jun 25, 2019 12:51 am
koburg offline
Sorry for my late response because I have not yet been able to use "tail -F /var/log/piBeacon.log"
because the pibeacon is always going down mostly when im not home :?
but when the pibeacon is "down" I can not always ping it.
Skærmbillede 2019-06-17 kl. 10.32.38.png (10.74 KiB) Viewed 2331 times
what I mean is it goes from "UP" to "DOWN" to "EXPIRED"
and when It do that it will "restart" all the triggers connected thru the beacons I use.
it have not behaved like this before. I also discovered my second pibeacon that is expired mostly all the time.
Tue Jun 25, 2019 5:42 pm
Could you be so kind and upgrade to the latest version.
In order to understand I really need to see some logfiles.
We could do an online session - teamviewer- works best.
Then I can likely fix that in 10 minutes- from experience.
If you like, send me your email + phone number to karlwachs at me com
