1 wire sensor don't work in pibeacon
Sun Mar 11, 2018 1:54 pm
rml2112 offline
I re-installed this plugin and I finally got it to be able to see my two raspberry pi's however I can't seem to get the 1 wire sensor to work
Here is part of my log file
Reloading plugin "piBeacon 7.81.210"
Stopping plugin "piBeacon 7.81.210" (pid 13715)
Stopped plugin "piBeacon 7.81.210"
Starting plugin "piBeacon 7.81.210" (pid 15820)
piBeacon setting parameters for indigo version: >>7<<
Started plugin "piBeacon 7.81.210"
piBeacon starting piBeacon
piBeacon logfile handling to : /Library/Application Support/Perceptive Automation/Indigo 7/logs/com.karlwachs.piBeacon/piBeacon.log
piBeacon --V 7.81.210 initializing
piBeacon .. subscribing to indigo variable changes
piBeacon .. initalized, log info in : /Library/Application Support/Perceptive Automation/Indigo 7/logs/com.karlwachs.piBeacon/piBeacon.log
Mar 11, 2018 3:31:28 PM
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-80.0,-59.0,7,"",30]],"reason":1,"secsCol":51,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796688.704203},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-89.7,101.0,24,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-75.1,-59.0,9,"",30]],"reason":1,"secsCol":54,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796690.054248},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","program":"getsensorvalues","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"pi":"2","program":"getsensorvalues","ipAddress":"10.0.0.102"}" from 10.0.0.102
Mar 11, 2018 3:32:20 PM
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520796740.634929}}" from 10.0.0.36
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"2f234454cf6d4a0fadf2f4911ba9ffa6-9-2",-80.1,-59.0,8,"",30]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796749.025124},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-87.1,101.0,27,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-68.8,-59.0,4,"",30]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796750.293641},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
Mar 11, 2018 3:33:21 PM
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520796801.715856}}" from 10.0.0.36
WebServer request to set variable "pi_IN_Alive" value to "{"pi":"2","temp":"47.2","ts":{"tz":"EDT","time":1520796804.670142},"program":"master","i2c":["i2c.ERROR:.no.such.file....redo..SSD?"],"ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-79.7,-59.0,7,"",30]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796809.299864},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-88.5,101.0,23,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-74.9,-59.0,7,"",30]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796810.471985},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_Alive" value to "{"pi":"1","temp":"44.4","ts":{"tz":"EDT","time":1520796820.805163},"program":"master","i2c":[],"ipAddress":"10.0.0.36"}" from 10.0.0.36
Mar 11, 2018 3:34:23 PM
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520796862.937354}}" from 10.0.0.36
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-80.4,-59.0,5,"",30]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796870.065195},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-88.6,101.0,25,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-74.2,-59.0,8,"",30]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796870.750728},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
Mar 11, 2018 3:35:12 PM
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"01060303edfe05-2388-26988",-87.8,101.0,19,"",13],["4C:6B:B8:3B:A3:C3",2,"ff4c000c0e008709ecc0d61c5590-38254-49647",-97.0,-102.0,1,"",23],["5C:F3:70:81:04:19",1,"2f234454cf6d4a0fadf2f4911ba9ffa6-9-1",-75.0,-59.0,4,"",30]],"reason":2,"secsCol":41,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796912.461261},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520796924.050468}}" from 10.0.0.36
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-80.3,-59.0,7,"",30]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796930.42068},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-81.4,101.0,10,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-72.5,-59.0,2,"",30],["4A:D9:F2:AF:2B:19",2,"011a0aff4c001005-2576-13606",-95.0,108.0,1,"",14]],"reason":2,"secsCol":20,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796932.702443},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-82.0,101.0,1,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-78.0,-59.0,1,"",30],["40:9D:16:44:09:AB",2,"011a0aff4c001005-2832-311",-84.0,48.0,1,"",14],["4A:D9:F2:AF:2B:19",1,"x-x-x",-90.0,108.0,1,"",14]],"reason":2,"secsCol":1,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796934.477342},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-81.0,-59.0,1,"",30],["40:9D:16:44:09:AB",2,"011a0aff4c001005-2832-311",-83.0,48.0,1,"",14]],"reason":2,"secsCol":3,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796934.475911},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
Mar 11, 2018 3:36:25 PM
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520796985.437838}}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-87.8,101.0,24,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-67.9,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-92.3,48.0,158,"",14],["4A:D9:F2:AF:2B:19",1,"x-x-x",-105.0,108.0,1,"",14]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520796994.615066},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"2f234454cf6d4a0fadf2f4911ba9ffa6-9-2",-80.6,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-84.6,48.0,173,"",14]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520796994.726866},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
Mar 11, 2018 3:37:13 PM
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-88.4,101.0,17,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-65.8,-59.0,4,"",30],["78:BD:BC:7E:99:FE",5,"x-x-x",-96.0,0.0,1,"",28],["40:9D:16:44:09:AB",1,"x-x-x",-92.2,48.0,65,"",14]],"reason":5,"secsCol":38,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520797033.137707},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["4C:6B:B8:3B:A3:C3",2,"ff4c000c0e0089094b5e7219038d-43249-41253",-94.0,-66.0,1,"",23],["B8:27:EB:0A:79:23",1,"x-x-x",-80.0,-59.0,5,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-84.8,48.0,83,"",14]],"reason":2,"secsCol":41,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520797036.279118},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"01060303edfe05-2388-26988",-89.0,101.0,1,"",13],["4C:6B:B8:3B:A3:C3",5,"ff4c000c0e008a0946415ee45b1e-7173-13345",-95.0,-20.0,1,"",23],["5C:F3:70:81:04:19",1,"2f234454cf6d4a0fadf2f4911ba9ffa6-9-1",-65.0,-59.0,1,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-93.8,48.0,11,"",14]],"reason":5,"secsCol":3,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520797036.771766},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_2" value to "{"pi":"2","program":"getsensorvalues","ipAddress":"10.0.0.102","ts":{"tz":"EDT","time":1520797044.816132}}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520797046.622458}}" from 10.0.0.36
Mar 11, 2018 3:38:14 PM
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["D1:A4:4A:DA:28:ED",5,"x-x-x",-92.0,101.0,1,"",13],["4C:6B:B8:3B:A3:C3",1,"x-x-x",-94.2,-58.0,8,"",23],["B8:27:EB:0A:79:23",1,"x-x-x",-80.0,-59.0,6,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-85.0,48.0,120,"",14]],"reason":5,"secsCol":57,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520797093.953009},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-89.0,101.0,20,"",13],["4C:6B:B8:3B:A3:C3",1,"x-x-x",-97.2,-59.0,16,"",23],["5C:F3:70:81:04:19",1,"x-x-x",-72.9,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-92.2,48.0,118,"",14]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520797096.943621},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520797107.799315}}" from 10.0.0.36
Mar 11, 2018 3:38:56 PM
Z-Wave Debug polling status of node "005 - Laundry Room Light"
Z-Wave Debug SENT requestRelayStatus: 01 09 00 13 05 02 25 02 25 E3 03
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 05 03 25 03 00 D2
Z-Wave Debug . . requestRelayStatus: node 005, endpoint None, value 0
Mar 11, 2018 3:39:14 PM
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["B8:27:EB:0A:79:23",1,"x-x-x",-80.4,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-87.4,48.0,52,"",14]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520797154.294089},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-87.5,101.0,24,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-66.4,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"001e9e6e9e55df81278d8ee407801005-2832-311",-88.9,48.0,86,"",30]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520797157.233933},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520797169.303164}}" from 10.0.0.36
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["D1:A4:4A:DA:28:ED",5,"01060303edfe05-2388-26988",-95.0,101.0,1,"",13],["B8:27:EB:0A:79:23",1,"x-x-x",-80.0,-59.0,2,"",30],["40:9D:16:44:09:AB",1,"011a0aff4c001005-2832-311",-85.5,48.0,44,"",14]],"reason":5,"secsCol":17,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520797172.139526},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
Mar 11, 2018 3:40:17 PM
WebServer request to set variable "pi_IN_2" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-87.9,101.0,15,"",13],["5C:F3:70:81:04:19",1,"x-x-x",-68.6,-59.0,5,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-90.6,48.0,116,"",14]],"reason":1,"secsCol":60,"mac":"B8:27:EB:0A:79:23","program":"beaconloop","ts":{"tz":"EDT","time":1520797217.36727},"pi":"2","ipAddress":"10.0.0.102"}" from 10.0.0.102
WebServer request to set variable "pi_IN_1" value to "{"pi":"1","sensors":{"Wire18B20":{"1648935879":{"badSensor":"badSensor,noinfobadSensor,noinfobadSensor,noinfobadSensor,noinfo"}}},"program":"getsensorvalues","ipAddress":"10.0.0.36","ts":{"tz":"EDT","time":1520797230.563961}}" from 10.0.0.36
WebServer request to set variable "pi_IN_1" value to "{"msgs":[["D1:A4:4A:DA:28:ED",1,"x-x-x",-93.0,101.0,1,"",13],["B8:27:EB:0A:79:23",1,"2f234454cf6d4a0fadf2f4911ba9ffa6-9-2",-79.6,-59.0,7,"",30],["40:9D:16:44:09:AB",1,"x-x-x",-85.0,48.0,135,"",14]],"reason":1,"secsCol":60,"mac":"5C:F3:70:81:04:19","program":"beaconloop","ts":{"tz":"EDT","time":1520797232.433919},"pi":"1","ipAddress":"10.0.0.36"}" from 10.0.0.36
here is an ssh to 10.0.0.102
pi@raspberrypi:~ $ cat /sys/bus/w1/devices/28-*/w1_slave
37 fe 4b 46 7f ff 0c 10 df : crc=df YES
37 fe 4b 46 7f ff 0c 10 df t=-28562
pi@raspberrypi:~ $
it is a DS18B20 sensor
Do you have any ideas?
I had a drive crash on my mini server a couple of weeks ago and I trying to rebuild this
Sun Mar 11, 2018 2:00 pm
Re: 1 wire sensor don't work in pibeacon
v .211 should fix it .
Sun Mar 11, 2018 3:22 pm
rml2112 offline
Works Great Now
Thank You
Users browsing this forum: No registered users and 19 guests
