Un Ignore Beacon
Mon Nov 06, 2017 4:32 pm
andarv offline
Un Ignore Beacon
During one update one of my beacons just disappeared (entire device), I'm not sure how... Probably something I did but can't figure out what.
Now I can't get it back, it shows in XY's app so I assume it's alive and kicking...
During several attempts i got it back for a few minutes but it's something wrong, it doesn't report UUID nr correct.
I have tried to Un ignore it from plugin menu, both individually and family, but it still shows as ignored?
This is what the log says when i'm trying to un-ignore
spawn sftp -o ConnectTimeout=15 pi@192.168.1.22
pi@192.168.1.22's password:
Connected to 192.168.1.22.
sftp> rm /home/pi/pibeacon/temp/rejec*
Removing /home/pi/pibeacon/temp/rejec*
Couldn't delete file: No such file or directory
sftp> lcd '/Users/Anders/indigo/piBeacon///all'
sftp> put *  /home/pi/pibeacon/
Uploading beacon_UUIDtoIphone to /home/pi/pibeacon/beacon_UUIDtoIphone
But atleast one pi finds the beacon?
piBeacon                        variable changed-----------------------------------
 {"msgs":[["00:EA:23:40:9D:74",1,"x-x-x",-80.8,-60.0,38,"",30],["00:EA:23:28:AC:A4",1,"x-x-x",-32.0,-60.0,41,"",30]],"reason":1,"secsCol":60,"mac":"B8:27:EB:8B:D5:61","program":"beaconloop","ts":{"tz":"CEST","time":1510007199.852809},"pi":"0","ipAddress":"192.168.1.20"}
Skärmavbild 2017-11-06 kl. 23.13.00.png (100.89 KiB) Viewed 1334 times
Mon Nov 06, 2017 6:06 pm
Un Ignore Beacon
which beacon do you mean: ..A4:87 / A4:84? don't see those in the message..
As for the UUID: there is an option to shorten the messages (PRI to send full UUID .. the UUID are half of the messages and as they do not change that often they don't need to be send overtime.) . If it is off, it will be sending the UUID only every 10th message or so.
could you post the content of :
/Users/yourid/indigo/piBeacon/all/beacon_ignoreMAC
and
/Users/yourid/indigo/piBeacon/all/beacon_ignoreUUID
When beacons are "unignored" from not existing as a device they will only reappear when you accept new beacons.
unignore beacons is overruled by " do not accept new beacons".
I will double check the ignore/unignore parts.
the ignore mac file should look like:
["60:03:08:B7:00:03", "CB:4A:59:D7:C6:6B", "55:B3:3E:D7:AB:93", "D2:6E:5A:3B:94:93", "54:57:45:04:5C:3E", "F1:4C:CE:08:E4:80", "00:1A:7D:DA:71:11", "C5:9A:40:BA:DF:5A", "00:00:00:00:07:01", "06:06:77:48:FB:8B", "40:16:3B:DD:08:7D", "C8:69:CD:86:1D:8F", "3A:14:A1:0F:27:0E", "28:7C:62:C8:68:3E", "28:F0:76:72:D3:49", "6F:6C:4A:1F:AB:8E", "7E:11:0E:44:EF:67"]
Tue Nov 07, 2017 1:44 pm
andarv offline
Re: Un Ignore Beacon
My mistake, after looking at to many MAC i got confused, those belong to beacons that work.
Its set to only send every 10th. But shouldn't new beacons get a UUID nr in notes?
and
Both are empty except
But my ignore files aren't stored in that location. My folder path is /Users/id/Document/pibeacon/all/
And are actually "ignoreMAC" and "ignoreUUID"
it's set to accept new beacons (and junk) no restrictions in Tx power.
The green beacon was actually accepted when i tried to reinclude it (alot of trial and error) but doesn't report any more.
I'm beginning to think that there is something more thats wrong, the other two working beacons doesn't get any status from the other PI's either.
Skärmavbild 2017-11-07 kl. 20.40.46.png (29.25 KiB) Viewed 1277 times
Skärmavbild 2017-11-07 kl. 20.33.48.png (17.01 KiB) Viewed 1277 times
Tue Nov 07, 2017 5:37 pm
Could you upgrade to the latest v ?
Tue Nov 07, 2017 6:10 pm
Also.
When switching new beacons on it takes some time to get to The rpi
The rpi has been rejecting the beacons and for them it is not new. So it might take some iterations before it will send the uuid again
If you just have a few rpi and beacons simply switch on the send uuid always option
Users browsing this forum: No registered users and 24 guests
