- Posted on
Wed Oct 11, 2017 3:34 pm
offline
i tried.. no delay < 0.5 secs..
ok could you set debug output to high in the lower section of config (RPI)
then ssh pi@..
with
tail -f /run/user/1000/pibeacon/execcommands.log
you should see something like this when you switch device off/on in indigo
20171011-16:29:12 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'26', u'inverseGPIO': False, u'command': u'down', u'device': u'OUTPUTgpio-1-ONoff'}
20171011-16:26:41 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'26', u'inverseGPIO': False, u'command': u'up', u'device': u'OUTPUTgpio-1-ONoff'}
if >>> u'startAtDateTime': 0 << , is right .. and these line apple immediately :
next thing to check is:
= how is the relay connected?
= can you manually trigger the relay, connect the relay board input pin to +3.3 and 0 and see if it clicks immediately
