pibeacon error looping in the indigo event window.
Mon Jul 24, 2017 8:30 pm
kevinb67 offline
I just installed my Rpi 3 today with the latest plug in while running indigo 6. This error keeps looping. I cannot find any reference to this in the forum. Is this normal?
Thank you
Kevin
piBeacon in Line '10577' has error='Python argument types in
Device.updateStateOnServer(Device, dict)
did not match C++ signature:
updateStateOnServer(CDeviceBase {lvalue}, CCString key, boost::python::api::object value, int decimalPlaces=-1, bool triggerEvents=True, bool clearErrorState=True, boost::python::api::object uiValue=None)'
Mon Jul 24, 2017 8:59 pm
Re: pibeacon error looping in the indigo event window.
As I don't have indigo 7 I can't test this. This is the line where the plugin tries to update the device state. ... it should work. Cold you switch debug on ? It's going to be a lot. I just need the lines before and after that error message.
Mon Jul 24, 2017 9:14 pm
kevinb67 offline
Thank you,
I turned on all logging. Here is the last error of many looping with everything until the error again.
2017-07-24 20:11:02.365   piBeacon   in Line '10577' has error='Python argument types in
2017-07-24 20:11:09.721   piBeacon   variable changed-----------------------------------
 description :
folderId : 1236140848
pluginProps : com.karlwachs.piBeacon : (dict)
readOnly : False
remoteDisplay : True
value : {"msgs":[["4A:F2:4F:9F:1F:90",1,"0-0-0",-85.0,0.0,82,"",11],["D0:03:4B:0B:AC:0A",1,"0-0-0",-44.7,0.0,81,"",11],["88:C6:26:8A:06:83",1,"0-0-0",-97.2,18.0,19,"",27],["3F:66:70:43:74:E7",1,"0-0-0",-77.9,63.0,81,"",15],["D0:03:4B:40:E3:31",1,"0-0-0",-87.1,0.0,82,"",11],["24:4B:03:22:D8:F7",1,"0-0-0",-98.0,0.0,3,"",31],["B8:78:2E:23:44:3A",1,"0-0-0",-78.7,62.0,83,"",15],["67:DC:1D:1B:67:65",1,"ff4c000c0e00e2487c2b1837de24-34766-50872",-98.0,-42.0,1,"",23],["1B:55:A2:4F:57:48",1,"0-0-0",-87.2,2.0,88,"",15],["08:66:98:F1:F3:A9",1,"0-0-0",-77.7,0.0,84,"",11],["3A:83:FF:EE:C5:22",1,"0-0-0",-44.7,60.0,85,"",15],["64:51:7E:77:02:76",1,"0-0-0",-75.6,0.0,94,"",11],["A0:99:9B:14:8A:BE",1,"0-0-0",-99.0,0.0,2,"",11],["7B:27:F3:F2:59:F7",1,"0-0-0",-64.2,0.0,64,"",11],["2C:B4:3A:1E:38:B2",1,"0-0-0",-91.6,61.0,51,"",15]],"ts":"1500952269=PDT","secsCol":"18","mac":"B8:27:EB:99:08:73","program":"beaconloop","pi":"0","ipAddress":"10.0.1.10"}
2017-07-24 20:11:09.733   piBeacon   in Line '10577' has error='Python argument types in
Mon Jul 24, 2017 9:16 pm
kevinb67 offline
description :
readOnly : False
Mon Jul 24, 2017 10:10 pm
could you download the latest 7-63-125..
Added a debug statement exactly for that error -- with that one you don't need to set any debug level
Mon Jul 24, 2017 10:41 pm
kevinb67 offline
Much appreciated. I think this is the part of the log you want.
piBeacon in Line '10649' has error='Python argument types in
piBeacon chList: [{'value': 'up', 'key': u'status'}, {'value': 'up', 'key': u'online'}]
piBeacon chList: [{'value': u'up', 'key': u'status'}, {'value': 'pi0', 'key': 'closestRPIText'}, {'value': '2017-07-24 21:38:58', 'key': u'Pi_0_Time'}, {'value': -85, 'key': u'Pi_0_Signal'}, {'decimalPlaces': 1, 'value': 54127.873563218396, 'key': u'Pi_0_Distance'}, {'value': 11, 'key': u'pkLen'}]
Mon Jul 24, 2017 11:02 pm
Ok I should be able to fix this. Want indigo version exactly are you using?
The state update Methode changed some time ago. Need to dum it down to very basic.
Tue Jul 25, 2017 6:29 am
please try v .7-63-126. Not tested, but should work for I6.
Tue Jul 25, 2017 8:22 am
kevinb67 offline
Thank you, I am running version 6.1.11.
With pibeacon 7.63.126 the original error went away.
New error is:
piBeacon in Line '7335' has error='empty string for float()'
On a side note I cannot believe how many beacons are near my house.
Kevin
Tue Jul 25, 2017 9:30 am
a) could you edit the RPI and set "sync time MAC to RPi:" to something, " do not sync" is fine that should fix it . Will add a check for that one = exist but empty.
or download this one, added check on property =empty
https://www.dropbox.com/s/8hn7lm119v11yiq/piBeacon-v-7-63-127.zip?dl=1
b) # of ibeacons: almost every car has an ibeacon (and many cars also drive by with wifi-hotspost on)
Tue Jul 25, 2017 9:48 am
kevinb67 offline
Thank you again.
The sync time MAC to RPi: was set to -select an item- I changed it to do not sync and it looks like that fixed it.
Later tonight I will download the new version to verify that fixed it as well.
Thank you so much for pibeacon and fingscan
K
Tue Jul 25, 2017 11:28 am
still suggest to upgrade to I7..
sqldatabase writes for pibeacon plugin are down factor by a really large factor
i6: if you have 5 states you like to update: 5 SQL writes with 20 states (all states are re-written)(*)
i7: ONE SQL write with 5 states updated.
karl
(*) as I have 10 beacon RPI and each sends a message every 60 secs updating >1* 5 vs 5*20 states for each reachable iBeacon (20) that really adds up.
