disable a pibeacon
Sat Jul 01, 2017 2:28 pm
Asconasny offline
disable a pibeacon
Hi.
Is it possible to disable a pibeacon for a while?
Without having to set it up again..
I have i switch that has probably stopped working while I'm at vacation, so the pibeacon connected to it will not answer to ping.
Ofcourse this happens while i am away, switch hasn't been rebooted for ages. Should have done it before i left.
its kinda flodding my log with error. : Does not answer to ping-, skipping update kinda thing.
This is a pibeacon i have up for a test run so i have actually no use for it now.
a note to self, put a z-wave relay on the switch so i can reboot it while away.
Sat Jul 01, 2017 4:29 pm
Re: disable a pibeacon
Does not answer ping is for rpi not for beacon. Yes you can disable rpi. Go to menu pibeacon basic rpi setup and disable that rpi
For ibeacon you should be able to disable the device in indigo device listing.
Sun Jul 02, 2017 2:15 am
Asconasny offline
worked perfect.
