piBeacon: 19- display in which room a beacon is
Posted: Tue Jan 17, 2017 10:47 pm
here is how to display a green dot for (each) beacon in a room where the beacon currently is:
setup a page with:
and ]
etc for each beacon (here b-radius-1,2) and room (room-0...9 if you have 10 RPI ) you like to cover
create the following images:
where most are empty circles and only RPI0+0.png RPI1+1.png... RPI9+9.png are a green dot.
and the control page will then look like:
beacon rad-2 is in room 0 and beacon rad-1 is in room 3
naturally this can be made look nicer with a real floor plan, but I hope you get the principle
you could use a name instead of the green dot eg make "rad-1" "rad2" an image and replace RPI1-1.png for the 2 files with the image of the beacon and leave the empty images as is this would add one image file for each beacon per room (= 10 images for each beacon for 10 rooms - 10 times the same image but with a different name: abc9-0.pgn ... abc9-9.png if the name of the beacon/image is abc)
and with some modified parameters ( caption on image)
setup a page with:
and ]
- Code: Select all
RPI0+-1.png RPI1+.png RPI2+0.png RPI3+1.png RPI4+2.png RPI5+4.png RPI6+4.png RPI7+5.png RPI8+6.png RPI9+7.png
RPI0+.png RPI1+0.png RPI2+1.png RPI3+2.png RPI4+3.png RPI5+5.png RPI6+5.png RPI7+6.png RPI8+7.png RPI9+8.png
RPI0+0.png RPI1+1.png RPI2+2.png RPI3+3.png RPI4+4.png RPI5+6.png RPI6+6.png RPI7+7.png RPI8+8.png RPI9+9.png
RPI0+1.png RPI1+2.png RPI2+3.png RPI3+4.png RPI4+5.png RPI5+7.png RPI6+7.png RPI7+8.png RPI8+9.png
RPI0+2.png RPI1+3.png RPI2+4.png RPI3+5.png RPI4+6.png RPI5+8.png RPI6+8.png RPI7+9.png RPI9+-1.png
RPI0+3.png RPI1+4.png RPI2+5.png RPI3+6.png RPI4+7.png RPI5+9.png RPI6+9.png RPI8+-1.png RPI9+.png
RPI0+4.png RPI1+5.png RPI2+6.png RPI3+7.png RPI4+8.png RPI6+-1.png RPI7+-1.png RPI8+.png RPI9+0.png
RPI0+5.png RPI1+6.png RPI2+7.png RPI3+8.png RPI4+9.png RPI6+.png RPI7+.png RPI8+0.png RPI9+1.png
RPI0+6.png RPI1+7.png RPI2+8.png RPI3+9.png RPI5+-1.png RPI6+0.png RPI7+0.png RPI8+1.png RPI9+3.png
RPI0+7.png RPI1+8.png RPI2+9.png RPI4+-1.png RPI5+0.png RPI6+1.png RPI7+1.png RPI8+3.png RPI9+4.png
RPI0+8.png RPI1+9.png RPI3+-1.png RPI4+.png RPI5+1.png RPI6+2.png RPI7+3.png RPI8+4.png RPI9+5.png
RPI0+9.png RPI2+.png RPI3+0.png RPI4+1.png RPI5+3.png RPI6+3.png RPI7+4.png RPI8+5.png RPI9+6.png
