Flow meter
Sat Aug 06, 2016 4:37 am
Mattias offline
Flow meter
I just ordered two water flow meters to measure how much i water the plants: https://www.amazon.com/Vktech-Effect-Se ... B00EVKVM02
Could i somehow use the pibeacon to count the pulses? (Or is it easier to use the arduino plug in?) (or none of the above) //mattias
Sat Aug 06, 2016 4:24 pm
Re: Flow meter
You can use the pibeacon. Set the pin to count mode That should count pulses if they are longer than 0.1 secs
Sat Aug 06, 2016 11:02 pm
Mattias offline
Re: Flow meter
Great, i'll try that (when i'm back from my vacation)
Sun Aug 07, 2016 9:05 am
Re: Flow meter
I will also post a piece of code for the arduino to do the same. It will go into the myStuff section.
Issue with the arduino is I cant store the current value in case it reboots the counter would start at 0 again.
