Small bug with OUTPUT-GPIO-1-Dimmer
Sat Jul 23, 2016 11:16 am
Hackencrash offline
Re: Small bug with OUTPUT-GPIO-1-Dimmer
Great! I've just downloaded 1.22.6 and now I see the correct input type assignment for pin 18
pi@bluepi:~/wiringPi $ gpio -g readall
 +-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 | ALT0 | 1 |  3 || 4  |   |      | 5V      |     |     |
 |   3 |   9 |   SCL.1 | ALT0 | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 1 | OUT  | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |  OUT | 1 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 1 | IN   | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI | ALT0 | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO | ALT0 | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK | ALT0 | 0 | 23 || 24 | 1 | OUT  | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 1 | OUT  | CE1     | 11  | 7   |
 |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
 |   5 |  21 | GPIO.21 |  OUT | 0 | 29 || 30 |   |      | 0v      |     |     |
 |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
 |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
However, after a reboot, pin 18 changes back to an output type again:
pi@bluepi:~ $ gpio -g readall
 |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 1 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |   IN | 1 | 13 || 14 |   |      | 0v      |     |     |
 |     |     |    3.3v |      |   | 17 || 18 | 1 | OUT  | GPIO. 5 | 5   | 24  |
Sat Jul 23, 2016 12:13 pm
Hackencrash offline
As you suggested, I've used another pin for now to get around the issue :)
Sat Jul 23, 2016 1:05 pm
You will need to edit the device and reselect the pin.
Sat Jul 23, 2016 1:10 pm
Hackencrash offline
I chose a pin that, by default, appears to be an input GPIO pin after a reboot and everything is working as expected. Not sure what's up with GPIO24 setting and staying as an output port post reboot!
Sat Jul 23, 2016 3:40 pm
gpio24 is a general pin, has no other function by default like RX/TX pins.
normally those pins should be undefined when not explicitly configured. could you check if you have an output device where gpio24 is still use?
here my listing:
gpio -g readall
 +-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
 |   4 |   7 | GPIO. 7 |   IN | 0 |  7 || 8  | 1 | OUT  | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | IN   | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
 |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
you can use the menu to print all properties of a device. The output devices are not present in the parameters file
looks like:
States : (dict)
     OUTPUT_00 :  (string)
     brightnessLevel : 0 (integer)
     status :  (string)
16:37:42 RPI info:   -
  "enableRebootCheck": "restartLoop",
  "enableSPIpinsAsGpio": "0",
  "enableTXpinsAsGpio": "0",
  "enableiBeacons": "1",
  "input": {
    "BLEconnect": {
      "65802248": "54:9F:13:3F:95:26"
    "DHTxx": {
      "961013608": ""
    "INPUTgpio-1": {
      "332019181": [
          "count": "off",
          "gpio": "24",
          "inpType": "low"
      "573070377": [
          "count": "off",
          "gpio": "21",
          "inpType": "low"
    "i2cBMExx": {
      "97310692": ""
  "ipNumberPi": "192.168.1.20",
  "ipNumberPiSendTo": "192.168.1.20",
  "output": {
    "OUTPUTgpio-1": {
      "588386865": [
          "gpio": "24",
          "outType": "0"
  "passwordPi": "xxx",
  "piDevId": 1422957889,
  "piMAC": "5C:F3:70:6D:DA:7A",
  "piNumberReceived": "0",
  "piOnOff": "1",
  "piUpToDate": 0,
  "rPiVersion": 0,
  "sensorList": "INPUTgpio-1*573070377,INPUTgpio-1*332019181,*118,BLEconnect*65802248,*17,",
  "sensorRefreshSecs": 90,
  "userIdPi": "xxx"
the GPIO pin only turns to an output pin the first it is used.
Sun Jul 24, 2016 1:45 pm
Hackencrash offline
Sorry Karl this has baffled me how you get to print all properties for a device?
From the piBeacon Plugins menu, I see Print device lnfo to log file but nothing appears to happen after I select and EXECUTE my rPi machine. The Indigo Event Log does nothing and I don't see anything resembling this info in the home folder on the rPi or in /var/log. I've selected all options for debug level for plugin: but that doesn't seem to make a difference.
What am I doing wrong :?:
Sun Jul 24, 2016 1:59 pm
In documents/pibeacon/pibeacon.log
If you have enabled writing to log file in config
Sun Jul 24, 2016 2:43 pm
Hackencrash offline
Thanks! I've moved from the original GPIO24 to GPIO25 which seems to work. Can't see the conflict on GPIO24 in this file though...
21:37:17 printing dev info for-Porch Panel Relay Board/257300703 -------------------------------
21:37:17 props:      -
com.karlwachs.piBeacon : (dict)
     OUTPUTstate : 0 (string)
     SupportsBatteryLevel : true (bool)
     address : Pi-1 (string)
     description : (#,gpio,type)(0:18,1);(1:27,1);(2:22,1);(3:5,1); (string)
     deviceDefs : [{"gpio": "18", "outType": "1"}, {"gpio": "27", "outType": "1"}, {"gpio": "22", "outType": "1"}, {"gpio": "5", "outType": "1"}] (string)
     displayState : status (string)
     gpio : 18 (string)
     outType : 1 (string)
     piDone : false (bool)
     piServerNumber : 1 (string)
     pinMappings : 0:18,1|1:27,1|2:22,1|3:5,1| (string)
     stateDone : false (bool)
21:37:17 states:     -
States : (dict)
     OUTPUT_00 : down (string)
     OUTPUT_01 : down (string)
     OUTPUT_02 :  (string)
     OUTPUT_03 : up (string)
     batteryLevel : 0 (integer)
     status :  (string)
21:37:17 RPI info:   -
  "enableRebootCheck": "reboot",
  "input": {
    "BLEconnect": {
      "1429868393": "DC:2B:2A:04:E7:A3",
      "314921500": "7C:01:91:BB:E1:13",
      "530206011": "E0:DB:10:60:72:3A"
    "INPUTgpio-1": {
      "1527957909": [
          "count": "off",
          "gpio": "12",
          "inpType": "high"
      "1590875007": [
          "count": "off",
          "gpio": "23",
          "inpType": "open"
      "462826025": [
          "count": "off",
          "gpio": "25",
          "inpType": "high"
    "Wire18B20": {
      "1592397868": ""
  "ipNumberPi": "192.168.1.121",
  "ipNumberPiSendTo": "192.168.1.121",
  "output": {
    "OUTPUTgpio-4": {
      "257300703": [
          "gpio": "18",
          "outType": "1"
          "gpio": "27",
          "outType": "1"
          "gpio": "22",
          "outType": "1"
          "gpio": "5",
          "outType": "1"
  "passwordPi": "",
  "piDevId": 20752057,
  "piMAC": "5C:F3:70:76:D2:FB",
  "piNumberReceived": "1",
  "piOnOff": "1",
  "piUpToDate": 0,
  "rPiVersion": 0,
  "sensorList": "INPUTgpio-1*1590875007,INPUTgpio-1*462826025,INPUTgpio-1*1527957909,Wire18B20*1592397868,BLEconnect*530206011,BLEconnect*314921500,BLEconnect*1429868393,",
  "userIdPi": ""
Sun Jul 24, 2016 3:26 pm
Could you switch on debug output
Something is sending a command to the pin.
Sun Jul 24, 2016 4:22 pm
I believe I found it.
the rPi remembers the last output settings if you set the output to be persistent. It sores it in the file
execcommands.current in home/pi/
delete that file and then either restart the rPi or do:
sudo python call beacon.py
that might fix it.
This is currently not covered: If you had an output pin defined and then delete that output device in indigo that. The rpi still remembers that. Deleting that file and rebooting will make it forget that- but also all other PERSISTENT (= restore after reboot option) output settings.
will add an option to delete that file in the menu.
the file look like:
cat execcommands.current
{"24": {"restoreAfterBoot": "1", "pin": "24", "inverseGPIO": false, "command": "up", "device": "OUTPUTgpio-1", "delayStart": 0}, "20": {"restoreAfterBoot": "1", "pin": "20", "inverseGPIO": false, "command": "up", "device": "OUTPUTgpio-4", "delayStart": 0}, "16": {"restoreAfterBoot": "1", "pin": "16", "inverseGPIO": false, "command": "up", "device": "OUTPUTgpio-4", "delayStart": 0}}
you could just delete the pin24 data, everything with restore after reboot will be set once the output part starts on the rPI
Mon Jul 25, 2016 1:25 am
Hackencrash offline
pi@bluepi:~ $ ls e*
execcommands.current  execcommands.py
pi@bluepi:~ $ cat execcommands.current
{"24": {"restoreAfterBoot": "1", "pin": "24", "inverseGPIO": false, "command": "up", "device": "OUTPUTgpio", "delayStart": 0}}
pi@bluepi:~ $
