Thu Jan 11, 2018 12:47 pm
released v 7.78.193
download at https://www.indigodomo.com/pluginstore/59/
support for IR 8x8 camera amg88xx. It can be used as sophisticated motion sensor.
Tue Jan 16, 2018 12:01 pm
released v 7.78.194
- bug fix
- reduced cpu time
- better amg88xx parameters
- cool layout of analogClock for RPI display
Fri Jan 19, 2018 10:06 pm
released v 7.78.197
= Significantly expanded DISPLAY features
dynamically overlay text/, triangles, lines, histograms, rectangles, points from devices/state or variables contents, Nice Analog clock , ...
= Some smaller bug fixes and exception handling
checkout the video:
https://www.dropbox.com/s/0aa2e9309i2sol6/IMG_0022.m4v?dl=1
Fri Jan 26, 2018 8:57 pm
released v 7.79.199 @https://www.indigodomo.com/pluginstore/59/
fixed beacons not changing
added full amg33 support. color shows the temperature in ºC. This not just an IR sensor but measures temperature
person sitting 2 m away
Screen Shot 2018-01-26 at 20.51.17.png (171.63 KiB) Viewed 4071 times
2 fingers 10 cm away
Screen Shot 2018-01-26 at 20.51.02.png (203.01 KiB) Viewed 4071 times
person standing 3 m away
Screen Shot 2018-01-26 at 20.50.51.png (206.25 KiB) Viewed 4071 times
The images are scaled up from 8x8 to 512x512 with interpolation in-between the measured points. you can chose 8x8,32x32.. 1024x1024 and w and w/o temp scale
Update frequency can be set, but don't go below 2 secs
Sun Jan 28, 2018 2:18 pm
released v 7.80.200 @https://www.indigodomo.com/pluginstore/59/
added:
== support for CO2 and VOC sensor SGP30
== for amg88 now offers color image or grey scale
== BLE stack restart if no BLE message for > 100 secs internally on RPI
fixed:
/0 in distance calculations when some RPI positions are not set .
Screen Shot 2018-01-28 at 14.17.17.png (62.39 KiB) Viewed 4032 times
Mon Jan 29, 2018 12:57 pm
released v 7.80.201 @https://www.indigodomo.com/pluginstore/59/
added:
== support for CO2 and VOC sensor CSS 811
fixed:
== RPI devices not created under certain circumstances
Thu May 31, 2018 9:06 pm
posted new version on plugin store https://www.indigodomo.com/pluginstore/59/ and [url]GitHub.com/kw123[/url].
added Sprinkler device and new light sensor VEML7700
just for completeness: all the devices supported:
===iBeacon
beacon
===BLECONNECT for phones
BLEconnect
===BLE temp sensor
BLEsensor
===Temp Pressure humidity quir quality ..
Wire18B20
DHT22
DHT11
TMP102
MCP9808
LM35A
T5403
MS5803
BMP180
BMP280
SHT21
AM2320
BMExx
bme680
pmairquality
sgp30
ccs811
===light: white, RGB infrared, ultraviolet ..
TCS34725
as726x
IS1145
OPT3001
VEML7700
VEML6030
VEML6040
VEML6070
VEML6075
TSL2561
mlx90614
===Infrared Camera
amg88xx
===Movements, gyroscopes, Magetometers
l3g4200
mag3110
hmc5883L
bno055
mpu9255
mpu6050
lsm303
===ADC
ADC121
ina219
ina3221
ADS1x15-1 1 channel
ADS1x15 4 channel
spiMCP3008
spiMCP3008-1
PCF8591-1
PCF8591
===Pulse sensors
INPUTpulse
===Capacitouch sensors
INPUTtouch-1
INPUTtouch-4
INPUTtouch-12
INPUTtouch-16
GPIO inoputs
INPUTgpio-1
INPUTgpio-4
INPUTgpio-8
INPUTgpio-26
===Distance, prximity
ultrasoundDistance
vl503l0xDistance
vcnl4010Distance
vl6180xDistance
apds9960
===special programs for you to design
mysensors
myprogram
===GPIO outpu
OUTPUTgpio-1-ONoff
OUTPUTgpio-1 1 channel
OUTPUTgpio-4
OUTPUTgpio-10
OUTPUTgpio-26 26 channel
===Radio
TEA5767
===DAC
MCP4725
PCF8591dac
===various display types
display
neopixel
neopixel-dimmer
neopixelClock
===sprinkler
===car
combine beacons to detect status of car
Sun Jun 03, 2018 11:27 am
posted v 7.85.219 on indigo store and GitHub.com/kw123.
This version allows the use of authentication keys (secure no password login) when ssh or sftp to the RPI
see viewtopic.php?f=187&t=20789 how to install and use it.
Added some functions to sprinkler device
fixed a bug with VEML7700 light sensor
Sun Jun 10, 2018 8:28 pm
posted v 7.86.220 on indigo store and GitHub.com/kw123.
Added CO2 sensor MH-Z19, it is an IR light sensor that measures absorption in the IR spectrum. this is the version with the serial to I2C converter : "10000ppm MH-Z16 NDIR CO2 Sensor with I2C/UART Interface Adaptor"
This sensor has an accuracy of ~5% (+-25ppm at not mall Co2 levels)
can be used for detection of larger changes of CO2 eg blowing at it ( values goes from 410 to ~1400ppm) , cooking detection in kitchen, CO2 in heating rooms....
Fixed a bug introduced in the last versio: parameters file was not tagged as updated on the RPI
Screen Shot 2018-06-10 at 21.28.19.png (219.41 KiB) Viewed 3836 times
Tue Jun 19, 2018 10:00 am
released v 7.88.222 indigo store and GitHub.com/kw123.
added:
==Lightning detection sensor as3935
this sensor-- ~ $23-- detects lighting strikes up to 30km away. Best is to use 2 or more in your house to suppress miss identified electric disturbances. The plugin sets a variables
lightningEventDate = date of last event if >=1 detectors fired
lightningEventDevices = number of detectors detecting event, only if >1
you can set the time window when 2 detectors must fire to be considered one event in config (secs to minutes)
This allows for a really nice early warning for an approaching thunderstorm
You can set sensitivities to suppress disturbances in device edit ... eg with a electric drill on/off you can simulate a lighting event holding it next to the device
there is a also a board that simulates lighting, but it works ONLY on an arduino (5V with the connectors fitting onto the arduino board)
I have tried "switch doc lab" and "playing w fusion devices " versions. The switch doc has some issues with fixed i2c address, (either 0x02 or 0x03 are fixed per device ) and they do not show up on an i2cdetect scanned you need to add a pulp resistor for i2c if this is your only i2c device.
The "playing w fusion devices" works flawless . Still waiting for some Chinese versions.
YOU NEED to set the tuning capacitor use on the board in device edit. It is written on the package (mine were: fusion 48pF, switch do 72 pF) -- don't throw the package away!
==CO2 sensor MH-Zxx (use MH-Z19 .. latest device version) IR absobption through i2c and Serial
this is the latest version of the CO2 sensors. with serial support. added several features to set sensitivity etc.
==added recovery from hanging sftp sessions
in very rare circumstances a sftp port was occupying the socket that piBeacon was using to receive messages from the RPI. The plugin now can recover from that - after a reload killing that process when restarting the socket listener
Fixed
==fixed bug for display updates, changing access rights of parameter file.
if you want to know: had to add "chown pi:pi parameters " after update of file to make it changeable to regular program (was set to root; root)
== change web server to suppress logging:
Sun Jul 15, 2018 10:06 am
added device type "launch program"
see plugin store or GitHub/kw123
Sun Jul 22, 2018 10:48 am
new release : 7.90.224:
added support for up to 4 floor levels (eg basement, ground floor, 1, 2. or if you are in the the US: basement, ground floor, 2. floor, 3 floor) for ibeacon position display (think that should be enough floor levels)
see indigo store or GitHub for download
Wed Aug 01, 2018 6:54 am
new release 7.91.22
supports indigo status broadcasts , currently used by home way plugin
Mon Sep 17, 2018 2:38 pm
new version 7.92.232
bugfix and 2 new sensors:
- RG11 optical rain sensor no mechanical parts, has an option to trigger on the first rain drop and "bucket" size is variable from 0.0001 .. 0.001 .. 0.01 inches.
- si7021 temperature and humidity
Mon Sep 24, 2018 8:13 pm
v 7.93.237 posted
1. !! IMPORTANT!! BUG FIX. the parameters file was not properly updated on the RPIs with slow connections and under some circumstances
(touch temp/touchFile was not always executed and then the RPI does not know that there is a new parameters file)
2. added full support for RG11 rain sensor
Page 12 of 21 1 ... 9, 10, 11, 12, 13, 14, 15 ... 21
Users browsing this forum: No registered users and 32 guests
