this should only occur if the PI positions are not set in RPI device edit . == quick fix set the xyz positions of your RPIs
will add an IF in the position calculations
piBeacon setup pi response (1) message
piBeacon setup pi response (1) error
couldn't read file "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateAllFiles.exp": no such file or directory
kw123 wrote:in principle you should be able to add a sensor twice, as each sensor has its own dict section. , but I have not tried that . .. just try it.
as for min max, I can add that when I am back, just adding the min max/ yesterday .. states to device.xml I believe and may be add the device type to a list
Karl≠≠
kw123 wrote:could you post the exact error msg "seems to give fix sensor error"..
2018-08-26 12:41:47.217 piBeacon fixing 2 piBeacon Level Sensor 185 rpi copy 680385196 pi 5 sensori2cADS1x15
kw123 wrote:test version w min/Max, lastchanged sensor for ADC 1115
https://www.dropbox.com/s/a7s6bc3rd6lc7id/piBeacon.indigoPlugin.zip?dl=1
