kw123 wrote:this should do it:
http://alexba.in/blog/2013/01/06/settin ... spberrypi/
we could put this onto one of the RPI sensor-only RP. Doing this in parallel to the "ibeacon scanner" might slow things down , one or the other might miss some signals
BUT I don't have anything to test with ..
May be after I am done with the RPI- beacon position plot .. this is close be released. works nicely
Any chance of adding support for
MS5803-30BA pressure sensor
Eg.
https://github.com/ControlEverythingCom ... S5803-30BA
Planning on submersing in water tank (once mostly covered in epoxy) and using to measure water level and changes
Glenn
