to test which is which needs some analysis steps, but this seems to work:
1. enable accept new i beacons, wait 30 secs (the config file has to get to the RPI and the RPI has to read it )
2. but battery into new ibeacon and place next to one RPI
3. check if new ibeacon is created and check signal level, should be high at the RPI state you put it next
- if ok,
== if you have 2 RPI: move beacon to other RPI
wait 1 minute and check signal level
then take battery out and wait if it goes down. might take 2 minutes
== if you have RPI: take battery out and wait if it expires. then put battery back in.
then switch off accept new ibeacons
I have several directories. one for newly cerated ibeacons(piBeacons. and one for ID-ed beacons. Once I have id-ed a beacon I move it to the "production" folder (mine is called PI-beacons, while the default is piBeacon) and then some more for other things like pi-Cars, pi-sensors, pi-servers
- Screen Shot 2017-05-06 at 09.56.10.png (12.13 KiB) Viewed 958 times
