Problem with Geofence
Thu Dec 17, 2015 8:18 am
col offline
Just started to try the Geofence with an Indigo action I set up to enable some triggers , I get the notify message but the action in Indigo doesn't happen.
Any ideas?
Thu Dec 17, 2015 8:28 am
Gary_BBGames offline
Re: Problem with Geofence
Have you set "Notification Option" to "Yes"?
If so you will get an actionable notification, you can swipe on it on the iPhone and you will see an activate button.
On Apple Watch it will look like this:
Image Image
It's ideal for if you don't always want the action to trigger - for example, turning the lights out when other people are in the house.
Set "Notification Option" to "No" and you'll be golden.
Thu Dec 17, 2015 8:30 am
I really need to explain that button better as people often use it mistakenly.
Thu Dec 17, 2015 9:01 am
col offline
Are ok, so it won't do it automatically then?
Thu Dec 17, 2015 9:02 am
Set "Notification Option" to "No" and it will perform the action with no input from you.
Thu Dec 17, 2015 9:05 am
col offline
Ahh I wondered what that was for, thanks for your help
Thu Dec 17, 2015 9:08 am
Yeah, I added it as I had the issue of other people being in the house at times and didm;t want to leave them all in darkness.
In the next update there will be an "Hours Active" so you will be able to make it not turn the lights on in the day for example.
Thu Dec 17, 2015 12:34 pm
Maybe make it two separate options - ask user, just do it, or do it and notify.
Alright, that's three options...
Thu Dec 17, 2015 12:51 pm
But that is a much nicer way of getting the point across to the user :)
Thu Dec 17, 2015 12:54 pm
Tue Dec 29, 2015 11:07 am
I can't seem to get this to work or maybe I am misunderstanding something.
I have two actions set-up:
  1. Geofence EXIT
    • Invokes an action group to set a variable to True and write an 'Exit' message to the event log
    • Geofence set-up as Trigger On: Exit, Notify: Yes, Notification Option: No, Name: Geofence Exit
  2. Geofence ENTER
    • Invokes an action group to set a variable to False and write an 'Enter' message to the event log
    • Geofence set-up as Trigger On: Enter, Notify: Yes, Notification Option: No, Name: Geofence Enter
When I physically leave my home I get the notification exit message and when returning home I get the notification enter message. If in Home Remote I tap the GeoFence EXIT or Geofence ENTER buttons the action group is run and I get the variable set and messages in the log.
The bit I am missing is how to trigger the action when entering or exiting the geofence :?
Any help, suggestions or advice would be much appreciated :)
Thu Dec 31, 2015 2:42 pm
Hey Jon, sorry for the delay, been busy with Christmas stuff.
If you receive the notification and notification option is off then the action is being called from the phone, as the code to call one calls the other.
You are not receiving it (I'm guessing you check logs or would see a visual event?) so the problem is somewhere in the transmission. Is the command a local network one or a global one? If global, do you have cell phone reception when the action is called?
Fri Jan 01, 2016 9:57 am
I guess by Global you mean cellular i.e. I have left home and am outside the range of my LAN Wi-Fi. :)
I should have data access via cellular but how does the command transmission know where to go and how does it get into Indigo?
Fri Jan 01, 2016 12:23 pm
I mean are you using a local IP such as 192.168.0.10/indigo or are you using www.myserver.com/indigo or are you using a reflector?
Fri Jan 01, 2016 12:55 pm
I am using 192.168.... - I can se that this would be a problem. :(
What should I be using - A Reflector?
When I am out an about and want to Use Indigo Touch, I enable the VPN connection on my iPhone and then use iTouch - so the 192.168... isn't a problem.
If I use a Reflector to access Indigo via Home Remote - will Home Remote use that regardless of whether I am at home or not?
