SATI discussion
Tue Aug 18, 2015 8:34 pm
SATI discussion
please use this thread for comments & questions & suggestions & problems for SATI
Wed Aug 19, 2015 4:43 am
Re: SATI discussion
Hi Karl,
Just having a play with this and have detected a small bug:
Line '215' has error='not all arguments converted during string formatting'
Looks like the line number isn't included in the error text.
Also, on my system the Documents folder starts with an uppercase D and the SATI folder is uppercase which is relevant in the set pathX to "/users/" & myuserid & "/Documents/SATI/ line.
Thanks for producing this :D
Wed Aug 19, 2015 6:43 am
SATI discussion
The upper / lower case in the path should not matter. OS X should ignore that. (Depends how your hard disk is formatted . The standard format should be fine )
As for the error. The log file entry has a bit more info. The apple script only gets the error text.
Could you post the command you are using. With all the " '.
Karl.
Wed Aug 19, 2015 7:43 am
Re: SATI discussion
Unfortunately, I can't exactly remember as I was playing around with your sample script. :(
I think it might have been trying to fail on this: EXECCMD Line '213' has error='ElementNotFoundError -- could not find device "GameRoomCeilingLights"'
I got the above error after amending your line 215 to read:
self.myLog(255, u"EXECCMD Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e) )
As you can see I was just trying it out and I would expect to get an error as I don't have a device named GameRoomCeilingLights.
Next question (an Applescript one):
How do I insert an applescript variable as a replacement for value in the line:
set cmd to "\"setVariable;:;:;myVariableName;:;:;value\" "
Wed Aug 19, 2015 8:02 am
Re: SATI discussion
Answering my own question :) :
set cmd to "\"setVariable;:;:;myVariableName;:;:;" & value & "\" "
Wed Aug 19, 2015 8:03 am
Re: SATI discussion
set command to "setVariable"
set variableName to "window1"
set windowValue to "55"
set seper to ";:;:;"
set cmd to "\""& command & seper & variableName & seper & windowValue &"\" "  -- the spaces before and after & are ignored
--is equivalent to
set cmd to "\"setVariable;:;:;window1;:;:;55\" "
hope that helps
Wed Aug 19, 2015 8:12 am
Re: SATI discussion
kw123 wrote:
... hope that helps
Yes it does - thanks :)
I have now got SATI working in conjunction with my Applescript to send SIRI commands to Indigo :)
For example, I can now say
Tell Indigo turn on study lamp
and it does :D
Wed Aug 19, 2015 8:30 am
Re: SATI discussion
cool ..
next release with subscriptions ++ posted
Wed Aug 19, 2015 10:52 pm
Re: SATI discussion
Jon,
could you post the code you are using?
Wed Aug 19, 2015 10:59 pm
Re: SATI discussion
just an example how to use SATI:
cd into ~/Documents/SATI
type:
echo "execCmd;:;:;indigo.device.turnOn('GameRoomCeilingLights')" > fromAS-1
and the lights GameRoomCeilingLights will turn on
or
echo "execCmd;:;:;indigo.server.log('hallo from applescript')" > fromAS-1
will print "hallo from applescript" in the indigo log file
Thu Aug 20, 2015 2:08 pm
Re: SATI discussion
kw123 wrote:
Jon,
It's a little bit convoluted and based on an AppleScript posted here by mrmatt68
The script is modified to make use of your SATI plugin which must be installed in order to update an indigo variable.
I have removed all the SIRI command interpretation from the Applescript and now this is done in Indigo using standard Indigo triggers.
You need to setup a separate apple account that you can send messages to from SIRI (I have named the account indigo for obvious reasons. :)
In the messages App on the Indigo mac, set-up an account with this new AppleID and in the Messages App, set Preferences... > General > AppleScript Handler to point at the script below e.g. indigo.applescript
The AppleScript looks like this (change to enter your relevant details):
(* File: Indigio Remote Control.applescript *)
using terms from application "Messages"
    -- handler to respond to all incoming messages.
    on runiTunesRemoteControl(theMessage, theBuddy)
        with timeout of 30 seconds
            set theResponse to "STARTING UP"
            if theBuddy is not equal to "TESTBUDDY" then
                set theBuddy to theBuddy's handle
                (* change the below email address to those allowed and decide response to those not allowed *)
                set Allowed to 0
                if theBuddy is equal to "<MOBILE 1 OR EMAIL 1>" then
                    set Allowed to 1
                end if
                if theBuddy is equal to "<MOBILE 2 OR EMAIL 2 (ETC)>" then
                    set Allowed to 1
                end if
                if Allowed is equal to 0 then
                    set theResponse to "ERROR: Access to Indigo not allowed for sender '" & theBuddy & "'"
                    return theResponse
                end if
            end if
            try
                set myuserid to "<USERID>"
                set pathX to "/users/" & myuserid & "/Documents/SATI/"
                set channel to 1
                set cmd to "\"setVariable;:;:;iMessage;:;:;" & theMessage & "\" "
                set cmd to "echo " & cmd
                do shell script cmd & " > " & pathX & "fromAS-" & channel as string
                set theResponse to "ACTIONED: " & theMessage
            on error errorMessage
                set theResponse to "ERROR: " & errorMessage
            end try
        end timeout
        return theResponse
    end runiTunesRemoteControl
    -- When first message is received, accept the invitation and send a greeting message from iTunes Remote Control.
    on received text invitation theMessage from theBuddy for theChat
        accept theChat
        send "Welcome to Indigo Remote Control." to theChat
        set theResponse to runiTunesRemoteControl(theMessage, theBuddy)
        send theResponse to theChat
    end received text invitation
    -- On subsequent messages, pass the message directly to iTunes Remote Control.
    on message received theMessage from theBuddy for theChat
        -- run the iTunesRemoteControl parser.
        -- send back the response.
    end message received
    -- Sample, so you can test run this through Script Editor.
    display dialog "Send a command to Indigo Remote Control:" default answer "status"
    set theMessage to the text returned of the result
    set theTestBuddy to "TESTBUDDY"
    set theResponse to runiTunesRemoteControl(theMessage, theTestBuddy)
    (*display dialog theResponse
    # The following are unused but need to be defined to avoid an error
    on received audio invitation theText from theBuddy for theChat
    end received audio invitation
    on received video invitation theText from theBuddy for theChat
    end received video invitation
    on received remote screen sharing invitation from theBuddy for theChat
    end received remote screen sharing invitation
    on received local screen sharing invitation from theBuddy for theChat
    end received local screen sharing invitation
    on received file transfer invitation theFileTransfer
    end received file transfer invitation
    on message sent theMessage for theChat
    end message sent
    on addressed message received theMessage from theBuddy for theChat
    end addressed message received
    on av chat started
    end av chat started
    on av chat ended
    end av chat ended
    (* HANDLERS *)
    on login finished for theService
    end login finished
    on logout finished for theService
    end logout finished
    on buddy became available theBuddy
    end buddy became available
    on buddy became unavailable theBuddy
    end buddy became unavailable
    on buddy authorization requested theRequest
    end buddy authorization requested
    on chat room message received theMessage from theBuddy for theChat
    end chat room message received
    on addressed chat room message received theMessage from theBuddy for theChat
    end addressed chat room message received
    on active chat message received theMessage from theBuddy for theChat
    end active chat message received
    on completed file transfer
    end completed file transfer
end using terms from
You need to substitute <USERID> and <MOBILE 1 OR EMAIL 1> with your values. Set <MOBILE 2 OR EMAIL 2> if you want more than one user to send commands (extend as necessary). The mobile or email address is of the users sending the message to Indigo i.e. probably yourself :wink:
I have defined two variables in Indigo: iMessage and iMessageLower
iMessage will contain the message from SIRI and iMessageLower is the same message converted to lower case so that condition checking in Indigo is less complicated.
At some point I might move the following logic into a generalised command interpreter plugin but for the moment as proof of concept it is all done using Indigo triggers and conditions with a bit of python scripting. :)
The first trigger is called SIRI:
  • Trigger:
    • Type: Variable Changed
    • Variable: iMessage
    • Changes
  • Condition
    • if conditions match rules
    • All
    • if variable - iMessage - does not contain - value - 'Lowered:'
  • Actions:
    1. execute embedded python script:
      iMessageId = <SUBSTITUTE YOUR ID> # iMessage
      iMessageLowerId = <SUBSTITUTE YOUR ID> # iMessageLower
      iMessage = indigo.variables[iMessageId]
      iMessageLowerValue = iMessage.value.strip().lower()
      indigo.variable.updateValue(iMessageLowerId, value=iMessageLowerValue)
      iMessageValue = str('Lowered: %s' % (iMessage.value))
      indigo.variable.updateValue(iMessageId, value= iMessageValue)
The above script will wait for the variable iMessage to change and then copy it to iMessageLower whilst lowercasing it. It changes the original iMessage variable by prepending 'Lowered:'.
The following three trigger examples takes a LIFX lamp in my study and allows me to turn it on, off and toggle it on/off. The lamp is called 'Study':
SIRI - Study [ON]:
  • Trigger:
    • Variable: iMessageLower
    • Changes
  • Condition
    • All
    • if variable - iMessageLower - does not contain - value - 'Actioned:'
    • if variable - iMessageLower - contains - value - 'on'
    • if variable - iMessageLower - contains - value - 'study'
    • Any
      • if variable - iMessageLower - contains - value - 'lamp'
      • if variable - iMessageLower - contains - value - 'light'
  • Actions:
      iMessageLower = indigo.variables[iMessageLowerId]
      iMessageLowerValue = str('SIRI Actioned: %s' % (iMessageLower.value))
      indigo.variable.updateValue(iMessageLowerId, value= iMessageLowerValue))
    2. turn on 'study'
    SIRI - Study [OFF]:
    • Trigger:
      • Changes
    • Condition
      • All
      • if variable - iMessageLower - contains - value - 'off'
      • Any
    • Actions:
      2. turn off 'study'
      SIRI - Study [TOGGLE]:
      • Trigger:
        • Changes
      • Condition
        • All
        • if variable - iMessageLower - does not contain - value - 'on'
        • if variable - iMessageLower - does not contain - value - 'off'
        • Any
      • Actions:
        2. toggle 'study'
        So once this is all set up, in this example you can just say to SIRI:
        Tell indigo turn study lamp on
        to turn on the lamp or
        Tell indigo study lamp
        (to toggle it).
        The logic just looks for on / off / study / lamp / light - so it is fairly simple but effective - just shows the power of Indigo's condition checks :)
        SIRI seems much better these days in understanding the spoken word :)
        Hope this helps - E&OE ;)
