Suggested addition to SQL utilities
Mon Mar 05, 2018 6:18 am
johnpolasek offline
In addition to allowing us to trim old data from individual variables and devices, it would be useful to have an option to truncate the entire database prior to a specified date; My SQLite database has better than 200 variable and device tables, and until it began behaving badly, I didn't realize that it had grown to over 13 Gig in the past two and a half years. I really don't need anything more than a month or so to drive IndigoPlot, so chopping it off at 6 months back twice a year would be a useful option if I didn't have to do each table individually. And once I saw the size, I was planning on switching to PostgreSQL, except the logger gets a timeout trying to bring up the configuration dialog... got a post in the SQLLogger plugin about that one.
Mon Mar 05, 2018 7:08 am
Re: Suggested addition to SQL utilities
Indigo has the function to trim the whole dB build in
But when you use SQLite the file actually does not shrink. It just creates empty spaces. Same for Postgres but it has many smaller files and handles it better.
You then need to create a dump file and reimport it.
The option to convert to Postgres might or might not work. It depends on how cleans you dB is.
And if you don’t understand it in detail I suggest to not go down that path.
Mon Mar 05, 2018 7:45 am
johnpolasek offline
I was going to simply start fresh with PostGreSQL, but since I can't configure SQLLogger to change engines, I guess I'll just have to keep destroying the SQLite database once a year or so until we change server hardware.
Mon Mar 05, 2018 11:02 am
"" I can't configure SQLLogger"" thats for Matt/Jay I guess
Mon Mar 05, 2018 7:51 pm
I just replied here. Thanks.
