indigo utilities discussion
Fri Nov 27, 2015 2:04 am
McJohn offline
Re: indigo utilities discussion
Thanks for the explanation Karl! Completely clear..
Fri Nov 27, 2015 12:42 pm
DVDDave offline
Hi Karl,
This looks like a very useful plug-in. However, WRT the database backup function, I think I'm confused on a basic point. I get an error in the backup log about /Library/Application Support/Perceptive Automation/Indigo 6/logs/indigo_history.sqlite being missing. Indeed I have no such file anywhere on my server. What is this file and how is it created? The only Indigo database I know of is <My_House_Name>.indiDb in the /Library/Application Support/Perceptive Automation/Indigo/Databases directory.
Thanks.
--Dave
Fri Nov 27, 2015 12:55 pm
McJohn offline
Hello Dave,
This is only useful when you use the SQL Logger Plugin (listed in the default Plugin list).
See for more info:
http://wiki.indigodomo.com/doku.php?id= ... sql_logger
Kind regards,
John
Fri Nov 27, 2015 2:46 pm
DVDDave offline
McJohn wrote:
Hello Dave,
See for more info:
Kind regards,
John
Ah, got it. Works now. Thanks, John.
--Dave
Sat Jan 16, 2016 9:55 pm
posted Version 1.5.1 http://forums.indigodomo.com/viewtopic.php?f=184&t=14825
added menu item to create the input file for http://forums.indigodomo.com/viewtopic.php?f=84&t=15251&p=108467&hilit=frank#p108467 graphic representation of your zwave environment (this part is written by Frank Nicholas)
Sun Jan 17, 2016 7:19 pm
version 1.5.2 posted
added:
(a) combined the zwave network info printout to log file with the graphviz .dot file creation in ONE menu item
(b) added the creation of the graphviz .svg output file if the tool is installed, all in one step.
install the graphviz system with
open terminal and type:
brew install graphviz
if you need home brew: got: http://brew.sh/
Mon Jan 18, 2016 12:39 pm
posted v 1.6.1:
added:
you can ping a device (ip number or dns name), output is send to the log file
Tue Jan 19, 2016 7:18 pm
Nice work! It could also be handy to have it output something like 'success' or 'failure' to a variable for triggering actions.
Tue Jan 19, 2016 10:26 pm
It much easier to do that in a script. ...
Wed Jan 20, 2016 2:49 am
yeah that's how I do it right now. :)
Tue Apr 19, 2016 6:06 am
posted v1.7.2 in the utilities announcement thread.
Print all plugin names and process ID to the log file.
====> when you want to know which of the plugins in activity monitor is the plugin you want to look at(*) and don't know which one of the 20 is it.:
(*) for eg CPU consumption etc..
output of print plugin NAMES and process IDs to log file:
  utilities                       ---------------------pluginName------------         ID        CPU
  utilities                       .Action Collection                                1624    0:36.47
  utilities                       Group-Trigger                                     1625    0:34.63
  utilities                       INDIGOplotD                                       1626    2:36.35
  utilities                        |- indigoMPplot.py                               1640    9:27.17
  utilities                       miniPLOT                                          1627    0:35.20
  utilities                       Plugin Developer Documenter-3                     1629    0:35.76
  utilities                       SQL Logger                                        1630    0:37.31
  utilities                       Virtual Devices                                   1631    0:36.03
  utilities                       piBeacon                                          5395    0:00.78
  utilities                       utilities                                         5558    0:00.24
download from http://forums.indigodomo.com/viewforum.php?f=184
Mon May 09, 2016 6:54 pm
roquej offline
Karl,
Trying to use the plugin per your suggestion and getting the error:
File "plugin.py", line 94, in startup
OSError: (2, 'No such file or directory', '/Users/house.roque/Documents/indigoUtilities/')
I remember having a similar issue with your piBeacon plugin because of the unique name of my user directory. Tried creating the directory manual, but didn't work.
Any suggestion?
JP
Mon May 09, 2016 8:48 pm
v 1.7.3
should fix this. This is the problem where I used userid to determine the home directory. and if that was not the same ... :oops:
Wed May 11, 2016 7:05 pm
roquej offline
Karl,
Thank you for the path fix. However, I ran into another issue. As per the enclosed image, the device states are not showing. I have reinstalled the plugin and tried many devices. None of states show.
Any suggestions?
JP
Screen Shot 2016-05-11 at 8.59.34 PM.png (99.13 KiB) Viewed 6334 times
Wed May 11, 2016 8:48 pm
click on "Select device" that will refresh the states.
this is a thing I don't like about the indigo interface: in order to get the fields sequentially addressed one has to go through hoops. So if sometimes the user needs to refresh some of the fields to make sure the required data is populated properly
sorry
