indigo utilities discussion
Wed Oct 07, 2020 2:23 pm
roquej offline
Re: indigo utilities discussion
Never mind. Just so Matt's post with the test version. Tried it and worked.
JP
Fri Nov 27, 2020 5:14 pm
aldonc offline
Hi, using Utilities in Trigger or Schedule Actions works fine when you select a Device to Retrieve records and write it to a file or Indigo log. When I select Variables and write to the Indigo log I get the following error (writing to a file doesn't show an error - just fails silently):
Nov 27, 2020 at 2:56:48 PM
   Trigger                         new trigger
   utilities Error                 ==================================================================================
   utilities Error                 error in querry:
Error: no such table: device_history_
It seems odd that there's a mention of device_history_ since I'm looking for a Variable.
Finally, this works ok when selecting Retrieve records from the Plugins - Utilities menu. Using SQLlite db.
Aldon
Tue Dec 08, 2020 1:22 pm
should be fixed in v .32 just posted.
sorry for responding so late.
Sat Dec 16, 2023 12:37 pm
McIntoshBear offline
I just downloaded and installed the "utilities" plugin.
How does one get around the macOS gatekeeper?
I think I figure out how to get around the macOS gatekeeper.
Is there a "User Manual"? :)
Received this error in the Event Log file when I attempted to get the temperature of my macMini.
Error (client) timeout waiting for plugin response from com.karlwachs.utilities for request UiAction
Error (client) received unexpected packet response UiAction (waiting for )
I tried to search the discussion but I did not have any success.
Sat Dec 16, 2023 12:41 pm
Is there an access limitation?
Check system setup / privacy & security
Sat Dec 16, 2023 12:46 pm
Action Group test utilities temp
utilities raw data fan temp .. info (-99=not available)
temp_AMBIENT_AIR_0:-99.0
temp_AMBIENT_AIR_1:-99.0
temp_CPU_0_DIE:-99.0
temp_CPU_0_DIODE:-99.0
temp_CPU_0_HEATSINK:-99.0
temp_CPU_0_PROXIMITY:-99.0
temp_ENCLOSURE_BASE_0:-99.0
temp_ENCLOSURE_BASE_1:-99.0
temp_ENCLOSURE_BASE_2:-99.0
temp_ENCLOSURE_BASE_3:-99.0
temp_GPU_0_DIODE:-99.0
temp_GPU_0_HEATSINK:-99.0
temp_GPU_0_PROXIMITY:-99.0
temp_HDD_PROXIMITY:-99.0
temp_HEATSINK_0:-99.0
temp_HEATSINK_1:-99.0
temp_HEATSINK_2:-99.0
temp_LCD_PROXIMITY:-99.0
temp_MEM_SLOT_0:-99.0
temp_MEM_SLOTS_PROXIMITY:-99.0
temp_MISC_PROXIMITY:-99.0
temp_NORTHBRIDGE:-99.0
temp_NORTHBRIDGE_DIODE:-99.0
temp_NORTHBRIDGE_PROXIMITY:-99.0
temp_ODD_PROXIMITY:-99.0
temp_PALM_REST:-99.0
temp_PWR_SUPPLY_PROXIMITY:-99.0
temp_THUNDERBOLT_0:-99.0
temp_THUNDERBOLT_1:-99.0
the plugin is using osx-temp-fan see plugin directory :
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/utilities.indigoPlugin/Contents/Server Plugin/osx-temp-fan
