indigo utilities discussion
Thu Feb 08, 2018 9:32 am
Re: indigo utilities discussion
I would like to point out that the 2 systems indigo internal db and what ever you do externally can become quickly out of sync.
If a device gets deleted added renamed would require a trigger to update that dB.
I am speaking from experience. This is a lot of work to make this kind of thing work.
Why don’t you do directly to the source ie indigo ?
Thu Feb 08, 2018 10:18 am
siclark offline
Yes, agree would need some updating and refreshing but manageable on adhoc basis if I saw issues on the results.
I am trying to setup a dashboard for my house in Qlikview which has free personal license for single use, and is a data visualisation tool I have used for many years, and can read data from postgresql.
With a table of all device ids I can create a loop to load in each table, and with the names against them, create a more useful name for that device. I have done this manually copying out from the log the list of all devices, but a pain to update this way.
Taking it to the next step, I can then create a different sql statement per device type, ie per PIR, thermostat, light switch etc, where each type has the same columns. As I loop through the device ids, if the name ends "PIR", or "Stat" etc (I am consistent with my naming of devices) then it will load that device into the right table.
I can then create interactive charts there .
Thu Feb 08, 2018 11:11 am
again the question why don't you go directly against indigo? the db is just an intermediate storage. can quick .. only read sql databases? or can you feed things directly?
Thu Feb 08, 2018 11:27 am
siclark offline
It does have a REST connector as well so guess it could query indigo directly for that information.?
Thu Feb 08, 2018 11:40 am
U can get states etc thru rest but don’t know if you can get a device list.
Thu Feb 08, 2018 12:02 pm
Colorado4Wheeler offline
You can get a device list via REST (assuming you are referring to Indigo's RESTful API):
http://127.0.0.1:8176/devices/
http://127.0.0.1:8176/devices.json/
http://127.0.0.1:8176/devices.xml/
http://127.0.0.1:8176/devices.txt/
Thu Feb 08, 2018 12:27 pm
Note that those lists don't include the ID, so you'll need to iterate through the lists, get the restURL element and use that to get the device details that includes the ID.
Thu Feb 08, 2018 6:00 pm
siclark offline
Thanks all. Yes realised that the device list from REST wouldn't do it without some hugely painful looping.
Think the easiest is to try and loop through the device list and get the id to name that way into a table.
Sorry Karl, seem to have hijacked your thread, this would have been better in my earlier script question thread.
Thu Feb 08, 2018 10:28 pm
to read the device states you don't need the devId, the devName is ok ..
just pay attention if the name changes .. I know thats not perfect, but it saves - in your case - a lot of programming I believe.
curl -u uid:pwd --digest http://192.168.1.xx:8176/devices/UniFi_sw_2_1_study.json
will give you all the states.. Actually I don't know how to use the devId to get the states through REST !? .. may be somewhere in the docu..
http://wiki.indigodomo.com/doku.php?id=indigo_s_restful_urls for the rest api
Fri Feb 09, 2018 10:02 am
I think he's using the Postgres DB directly and only needs the name to make his visualizations more readable.
The ID was added after the fact to the existing REST API - it's not used in any place other than returned with the device details so you can't get a device based in the ID. We're currently planning a pretty big revamp of the REST API as we reimplement the Indigo Web Server using the IOM (the current IWS implementation predates plugins, object IDs, and the IOM which is why it lacks features).
Fri Feb 09, 2018 10:06 am
There's a new plugin I can scrap then :). I was rewriting the API via a plugin.
Fri Feb 09, 2018 10:34 am
Yeah, that would probably not be the best use of your time...
Fri Feb 09, 2018 10:37 am
Lol, if I had a penny for each plugin that wasn't a good use of my time.... :shock: . That project only got a little bit of love when I utilized it in the HKB plugin (sort of), but it was slated for a month or two down the road before I lit it up anyway so I've only spent maybe 1-3 hours working on what's there now. Glad to not have to write it honestly.
Fri Feb 09, 2018 11:30 am
siclark offline
Exactly. Any idea on a timeline for the new REST API? Think I might stick with the manual table for now and wait for the API but will investigate automating it if I run out of other indigo tasks to do.
Fri Feb 09, 2018 12:00 pm
We don't like to give time estimates / ETAs, but it is a high priority item.
Page 8 of 11 1 ... 5, 6, 7, 8, 9, 10, 11
