indigo utilities discussion
Mon Jan 08, 2018 5:14 pm
Re: indigo utilities discussion
Yes that’s an option.
But then you get ts twice.
Can do that if you prefer.
Would be nice to have do
ts-local and * but not ts
Have not found how to do that
Mon Jan 08, 2018 5:51 pm
is this better?
   utilities                       print SQL data for device 375541516/wind sensor states: ['*']
   SQL command=                    /usr/bin/sqlite3  -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT id, strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , *  from device_history_375541516 WHERE ID > 0 ORDER by id  LIMIT 5;"
   SQL-OUTPUT:
id          ts_local             id          ts                   onoffstate  avgspeed    batterylevel  directiondegrees  directiontext  display     gust        lastupdated  signalstrength  temperature  type        windchill
2           2014-06-28-11:45:32  2           2014-06-28 16:45:32  False
3           2014-06-28-11:45:48  3           2014-06-28 16:45:48              0           0             0                                            0                        0               0            0           0
4           2014-06-28-11:45:58  4           2014-06-28 16:45:58              4.9         10            0                 N              4 mph       2.7         2014/06/28   5               0            2           0
5           2014-06-28-11:46:12  5           2014-06-28 16:46:12              3.4         10            0                 N              3 mph       2.7         2014/06/28   5               0            2           0
6           2014-06-28-11:46:40  6           2014-06-28 16:46:40              3.4         10            0                 N              3 mph       6.9         2014/06/28   5               0            2           0
Mon Jan 08, 2018 6:58 pm
Colorado4Wheeler offline
Hey, anything you do in regards to getting the system date displayed is A-OK with me Karl! That looks awesome, thank you!!
Mon Jan 08, 2018 7:06 pm
Oh and there isn't a way to exclude a column from * through a query. The alternative would be to copy it to another table and report that (SELECT * INTO plugin_output and then DROP COLUMN) or to do a quick field check beforehand so that when the user selects * you interpret that as looping through all fields except TS. I'm an SQL developer and have been down this path before.
Mon Jan 08, 2018 7:14 pm
It is easier to do this on the result in python
Mon Jan 08, 2018 9:59 pm
this https://www.dropbox.com/s/7q2wgce1eexukjk/utilities-v-1.12.10.zip?dl=1
will produce this:
   SQL command=                    /usr/bin/sqlite3  -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , *  from device_history_375541516 WHERE ID > 0 ORDER by id  LIMIT 10;"
   SQL-OUTPUT:
id          ts_local             onoffstate  avgspeed    batterylevel  directiondegrees  directiontext  display     gust        lastupdated  signalstrength  temperature  type        windchill
2           2014-06-28-11:45:32  False
3           2014-06-28-11:45:48              0           0             0                                            0                        0               0            0           0
4           2014-06-28-11:45:58              4.9         10            0                 N              4 mph       2.7         2014/06/28   5               0            2           0
5           2014-06-28-11:46:12              3.4         10            0                 N              3 mph       2.7         2014/06/28   5               0            2           0
6           2014-06-28-11:46:40              3.4         10            0                 N              3 mph       6.9         2014/06/28   5               0            2           0
7           2014-06-28-11:46:54              3.4         10            0                 N              3 mph       5.6         2014/06/28   5               0            2           0
8           2014-06-28-11:47:08              4.7         10            0                 N              4 mph       3.6         2014/06/28   5               0            2           0
9           2014-06-28-11:47:22              4.7         10            0                 N              4 mph       4.3         2014/06/28   5               0            2           0
10          2014-06-28-11:47:36              4.7         10            0                 N              4 mph       5.4         2014/06/28   5               0            2           0
11          2014-06-28-11:48:04              4.9         10            0                 N              4 mph       6           2014/06/28   5               0            2           0
   utilities                       record id# 0  2           2014-06-28-11:45:32  False
for sqlite
is this ok ? if yes will post to GitHub
reformatted the output in python (drop col 2, swap col 0,1)
Mon Jan 08, 2018 10:10 pm
Genius! Looks awesome!
Tue Jan 09, 2018 7:09 am
posted the final version on GitHub. Had to add code for "no header and/or no separator"
The trick to drop the regular TS column does not work if there are no columns in the output and no separator to id the columns (one of them is ok)
This is only for sqlite db and selection =*.
Time was already local for selection with specific columns and all of postgres
Tue Jan 09, 2018 3:00 pm
LOVE! Thanks Karl, it makes the report a lot more useful for me!
   SQL-OUTPUT:
id          ts_local             sensorvalue
1           2018-01-08-09:16:30  335.0
2           2018-01-08-09:17:11  335.0
3           2018-01-08-11:13:08  18.0
4           2018-01-08-11:13:31  376.0
5           2018-01-08-11:17:34  15.0
6           2018-01-08-11:18:03  371.0
7           2018-01-08-11:30:01  25.0
8           2018-01-08-11:30:31  362.0
9           2018-01-08-12:33:42  29.0
10          2018-01-08-13:31:51  378.0
11          2018-01-08-13:32:13  14.0
12          2018-01-08-14:32:51  229.0
13          2018-01-08-15:33:28  238.0
14          2018-01-08-16:34:06  221.0
15          2018-01-08-17:34:45  214.0
16          2018-01-08-18:35:23  216.0
17          2018-01-08-20:36:40  217.0
18          2018-01-08-21:37:20  218.0
19          2018-01-08-22:38:02  219.0
20          2018-01-08-23:12:44  0.0
21          2018-01-09-08:00:18  392.0
22          2018-01-09-09:00:19  186.0
23          2018-01-09-10:00:56  81.0
24          2018-01-09-11:01:35  22.0
25          2018-01-09-12:02:16  26.0
26          2018-01-09-13:02:52  21.0
Tue Jan 09, 2018 8:23 pm
Glad it works for you.
Mon Jan 29, 2018 11:40 pm
released v 1.14.11
added option to print all indigo store plugins sorted with latest release date
looks like this:
   Plugin Name                     web page -----------------------------------   Date released   Version
   piBeacon                        https://www.indigodomo.com/pluginstore/59/     Jan. 29, 2018   7.80.201
   Sensibo                         https://www.indigodomo.com/pluginstore/146/    Jan. 29, 2018   0.1.5
   NuVo Grand Concerto             https://www.indigodomo.com/pluginstore/66/     Jan. 28, 2018   2.0.2
   FindFriendsMini                 https://www.indigodomo.com/pluginstore/139/    Jan. 27, 2018   0.4.9
   Multitool                       https://www.indigodomo.com/pluginstore/145/    Jan. 25, 2018   1.0.14
   fingscan                        https://www.indigodomo.com/pluginstore/72/     Jan. 23, 2018   7.24.21
   Announcements                   https://www.indigodomo.com/pluginstore/141/    Jan. 19, 2018   0.4.0
   Shairport Sync                  https://www.indigodomo.com/pluginstore/144/    Jan. 18, 2018   1.0.0
   Eversolar Monitor               https://www.indigodomo.com/pluginstore/143/    Jan. 17, 2018   1.0.1
   NetworkOwl                      https://www.indigodomo.com/pluginstore/142/    Jan. 16, 2018   1.6.1
   Mac Apps                        https://www.indigodomo.com/pluginstore/92/     Jan. 14, 2018   0.0.6
Thu Feb 08, 2018 8:39 am
siclark offline
Whilst you have an option in utilities to output device names and ids to the log, it would be awesome if you could output the same to a postgres table as well, ie something with 2 columns, device_id, device_name? Or even do a generic one, so has columns of id, name and type, where type is device or variable?
Thu Feb 08, 2018 8:49 am
You mean creating a table in the indigo Postgres database? I would shy away from that. Indigo owns the dB. I don’t know what indigo would do if another tables is created.
Thu Feb 08, 2018 9:07 am
siclark offline
Yes I did... although indigo owns the database indigo_history or whatever its been called, what about creating in the postgres db, or the username one?
Thu Feb 08, 2018 9:28 am
siclark offline
Or I guess I could run it in a script, with a quick hack of asomethign found online, something along these lines?
import psycopg2
conn = psycopg2.connect(database = "userid", user = "postgres", password = "", host = "127.0.0.1", port = "5432")
cur = conn.cursor()
cur.execute('''CREATE TABLE DEVICES
(DEVICE_ID INT PRIMARY KEY NOT NULL,
DEVICE_NAME TEXT NOT NULL);''')
conn.commit()
for dev in indigo.devices:
cur.execute("INSERT INTO COMPANY (DEVICE_ID,DECIVE_NAME) \
VALUES (dev.id,dev.name )");
as as starting point?
Page 7 of 11 1 ... 4, 5, 6, 7, 8, 9, 10, 11
