Yes that’s an option.
But then you get ts twice.
Can do that if you prefer.
Would be nice to have do
ts-local and * but not ts
Have not found how to do that
utilities print SQL data for device 375541516/wind sensor states: ['*']
SQL command= /usr/bin/sqlite3 -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT id, strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , * from device_history_375541516 WHERE ID > 0 ORDER by id LIMIT 5;"
SQL-OUTPUT:
id ts_local id ts onoffstate avgspeed batterylevel directiondegrees directiontext display gust lastupdated signalstrength temperature type windchill
2 2014-06-28-11:45:32 2 2014-06-28 16:45:32 False
3 2014-06-28-11:45:48 3 2014-06-28 16:45:48 0 0 0 0 0 0 0 0
4 2014-06-28-11:45:58 4 2014-06-28 16:45:58 4.9 10 0 N 4 mph 2.7 2014/06/28 5 0 2 0
5 2014-06-28-11:46:12 5 2014-06-28 16:46:12 3.4 10 0 N 3 mph 2.7 2014/06/28 5 0 2 0
6 2014-06-28-11:46:40 6 2014-06-28 16:46:40 3.4 10 0 N 3 mph 6.9 2014/06/28 5 0 2 0
SQL command= /usr/bin/sqlite3 -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , * from device_history_375541516 WHERE ID > 0 ORDER by id LIMIT 10;"
SQL-OUTPUT:
id ts_local onoffstate avgspeed batterylevel directiondegrees directiontext display gust lastupdated signalstrength temperature type windchill
2 2014-06-28-11:45:32 False
3 2014-06-28-11:45:48 0 0 0 0 0 0 0 0
4 2014-06-28-11:45:58 4.9 10 0 N 4 mph 2.7 2014/06/28 5 0 2 0
5 2014-06-28-11:46:12 3.4 10 0 N 3 mph 2.7 2014/06/28 5 0 2 0
6 2014-06-28-11:46:40 3.4 10 0 N 3 mph 6.9 2014/06/28 5 0 2 0
7 2014-06-28-11:46:54 3.4 10 0 N 3 mph 5.6 2014/06/28 5 0 2 0
8 2014-06-28-11:47:08 4.7 10 0 N 4 mph 3.6 2014/06/28 5 0 2 0
9 2014-06-28-11:47:22 4.7 10 0 N 4 mph 4.3 2014/06/28 5 0 2 0
10 2014-06-28-11:47:36 4.7 10 0 N 4 mph 5.4 2014/06/28 5 0 2 0
11 2014-06-28-11:48:04 4.9 10 0 N 4 mph 6 2014/06/28 5 0 2 0
utilities record id# 0 2 2014-06-28-11:45:32 False
SQL-OUTPUT:
id ts_local sensorvalue
1 2018-01-08-09:16:30 335.0
2 2018-01-08-09:17:11 335.0
3 2018-01-08-11:13:08 18.0
4 2018-01-08-11:13:31 376.0
5 2018-01-08-11:17:34 15.0
6 2018-01-08-11:18:03 371.0
7 2018-01-08-11:30:01 25.0
8 2018-01-08-11:30:31 362.0
9 2018-01-08-12:33:42 29.0
10 2018-01-08-13:31:51 378.0
11 2018-01-08-13:32:13 14.0
12 2018-01-08-14:32:51 229.0
13 2018-01-08-15:33:28 238.0
14 2018-01-08-16:34:06 221.0
15 2018-01-08-17:34:45 214.0
16 2018-01-08-18:35:23 216.0
17 2018-01-08-20:36:40 217.0
18 2018-01-08-21:37:20 218.0
19 2018-01-08-22:38:02 219.0
20 2018-01-08-23:12:44 0.0
21 2018-01-09-08:00:18 392.0
22 2018-01-09-09:00:19 186.0
23 2018-01-09-10:00:56 81.0
24 2018-01-09-11:01:35 22.0
25 2018-01-09-12:02:16 26.0
26 2018-01-09-13:02:52 21.0
Plugin Name web page ----------------------------------- Date released Version
piBeacon https://www.indigodomo.com/pluginstore/59/ Jan. 29, 2018 7.80.201
Sensibo https://www.indigodomo.com/pluginstore/146/ Jan. 29, 2018 0.1.5
NuVo Grand Concerto https://www.indigodomo.com/pluginstore/66/ Jan. 28, 2018 2.0.2
FindFriendsMini https://www.indigodomo.com/pluginstore/139/ Jan. 27, 2018 0.4.9
Multitool https://www.indigodomo.com/pluginstore/145/ Jan. 25, 2018 1.0.14
fingscan https://www.indigodomo.com/pluginstore/72/ Jan. 23, 2018 7.24.21
Announcements https://www.indigodomo.com/pluginstore/141/ Jan. 19, 2018 0.4.0
Shairport Sync https://www.indigodomo.com/pluginstore/144/ Jan. 18, 2018 1.0.0
Eversolar Monitor https://www.indigodomo.com/pluginstore/143/ Jan. 17, 2018 1.0.1
NetworkOwl https://www.indigodomo.com/pluginstore/142/ Jan. 16, 2018 1.6.1
Mac Apps https://www.indigodomo.com/pluginstore/92/ Jan. 14, 2018 0.0.6
