Hello
just started using the map feature. The maps get updated which is great but the size is only 248 bytes.
so they do not open
all other functions of the plugin are working great.
You'll know if you have an API key issue if you suddenly find that you can't read the jpg files that iFindStuff creates. If you open the rogue file with a text editor like TextEdit you'll see the error message that Google has returned instead of the map.
