I've released version 1.0.46 which contains an important fix regarding distance calculations and ranges. I recommend updating immediately.
You can download and install the latest version from this link:https://www.dropbox.com/s/vtnxa5ssxvroga2/iFindStuff.zip?dl=0
What's new in version 1.0.46?
F/B75 - Ranges are not being managed correctly in Metric or Imperial units. Range is entered in ft or metres but compared with Miles and Kilometres. This was caused by an incorrect Geo Distance calculation which has now been corrected.
NOTE: Ranges are measured in Metres for Metres or Metric units and Feet for Imperial Units. Please keep this in mind when setting range values for GeoFences.
The following states are impacted:
deviceGeoDistance now shown in Metres or Feet depending on the units chosen
distanceHome is displayed in Metres, KiloMetres or Miles depending on your unit setting
deviceDistanceDisplay and deviceHomeDistanceDisplay are unaffected by the change
deviceAccuracy is shown in Metres or Feet depending on the units selected.
realDistanceHome is unaffected
There are no other changes in this version. Thanks to snowjay for spotting the error
Regards
Mike
