Latest Version 1.0.30 - Bug fixes and improved address mgt
Thu Oct 01, 2015 12:45 pm
Chameleon offline
Hi all
An outstanding issue has been the "Too many queries" for address look up that some users have suffered. This is due to the limited number of accesses to the API that are allowed per day by Google. I'm sourcing other providers at the moment (and hope to announce in the next few days) but until then I've implemented a logic fix.
You can download the latest version (1.0.30) of iFindStuff from this address:
https://www.dropbox.com/s/vtnxa5ssxvroga2/iFindStuff.zip?dl=1
What's new in version 1.0.30?
    B49 - "Too many queries" against devices - I've decided to implement a simple trap to limit the number of accesses made to the Google Reverse GeoFence API that has caused the "Too Many Queries" issue. Simply put, if a device hasn't actually moved since the last update there seems no point working out a new address. Of course there will be some movement between updates as the GPS system isn't 100% rock solid. But, if a device hasn't moved more than a few metres since the last update we can probably assume it's stationary.
    By default iFindStuff assumes 20 m (or 20ft) movement is acceptable for a stationary device. You can fine tune this against each device using the new "Distance a device can move and still be stationary" option. The entry depends on what units you're using. If you're set on imperial then enter a trigger value in feet, otherwise use metres.
    On testing I've found that this actually reduces my access to the API by over 70% with no loss of functionality. That seems a reasonable compromise until I can convince Bing that unlimited access for a few hundred users isn't going to kill their servers :D
    B61 - Send message action doesn't send message to Master Account Device - Fixed
    B62 - Inconsistent field display on Device Configuration Screen - Fixed
    B63 - Typo's on device screen - fixed
    B64 - Trigger names inconsistent and difficult to determine which is which - mitigated by changing some descriptions
Thanks for your support as ever - and the iPhone/iPad app is coming on :D
Regards
Mike
Fri Oct 02, 2015 1:39 am
Londonmark offline
Re: Latest Version 1.0.30 - Bug fixes and improved address m
Hi Mike,
Something seems to have gone wrong in 1.0.30 for me at least:
iFindStuff Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 2987, in runConcurrentThread
File "plugin.py", line 1177, in nextUpdateCalc
<type 'exceptions.KeyError'>: key holidayFrequency not found in dict
iFindStuff Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Looks as if it's something to do with the holiday frequencies...
Mark
Fri Oct 02, 2015 6:25 am
peteinau offline
Again, thanks for your hard work, loving the plugin! I get a similar issue to Mark with the following error:
File "plugin.py", line 2944, in runConcurrentThread
File "plugin.py", line 312, in iMapping
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/iFindStuff.indigoPlugin/Contents/Server Plugin/pyicloud/services/findmyiphone.py", line 78, in __getitem__
<type 'exceptions.KeyError'>: u'rowvzESz2vknJvx1Ydqkysuce4jQPX1I2dyJt/4CZ8aACChPcWNYceHYVNSUzmWV'
Pete
Fri Oct 02, 2015 6:49 am
TOPS offline
Hi All,
Same here, I think Mike is working on something at the moment which may be causing the error.....
Cheers
Fri Oct 02, 2015 8:51 am
Chameleon offline
Londonmark wrote:
Hi Mike,
Mark
Thanks Mark - you were right about the Frequencies - it's because I added a new field and it hadn't picked it up yet. I've trapped the error in version 1.0.35
I'll upload it later today...
Regards
Mike
Fri Oct 02, 2015 8:55 am
Chameleon offline
Pete
Pete
This is an interesting error because that's been trapped out in the latest version. The reason it happens is because when Find My Phone went and looked for the device it couldn't find it (maybe offline or out of signal). That'a not a problem and the system ignores that error automatically. However, that was introduced a couple of versions ago. I suggest that you update to the latest version (1.0.36 will be out in about an hour) and see if you still have the same problem. I suspect not "D.... If you do I'll investigate more.
Regards
Mike
Fri Oct 02, 2015 8:57 am
Chameleon offline
TOPS wrote:
Hi All,
Cheers
Yep - I was working hard to introduce new errors for me to fix apparently :D
I think I've sorted the issues so I'm going to release a new version (1.0.36) in a little while (about an hour).
Regards
Mike
Fri Oct 02, 2015 5:54 pm
peteinau offline
HI Mike,
Totally forget one of the family had moved to a new phone (named the same tho), so I deleted the device and added it again and it works!
Pete
Sat Oct 03, 2015 5:52 am
Chameleon offline
peteinau wrote:
HI Mike,
Pete
Cool - I've added extra trapping for that error as well.
Mike
