mclass wrote:Thaks for including me in in Alpha testing!
Loaded V0.4.25 successfully and configured my account and phone OK. Geolocation appears to work OK here in the Southern Hemisphere (Australia).
I then set up my wife's account, and attempted to create her iPhone device. However, I experienced similar problems to kw123 - no devices appeared in the drop down menu (just greyed out), despite the her Account Device showing as "Active" with the green dot. Attempts at reloading plugin, restarting computer and server and all sorts of combinations were without success.
In desperation deleted, and recreated my wife's Apple Account Device, and hey presto - there was her phone and iPad.
In experimenting with some of the features, I was able to plot all devices on a map, but then when I attempted to plot a selected device, there were no devices presented in the selection box - just greyed out. Similarly for sending a message to a device. I'm surmising that these are features yet to be implemented?
This is another great plugin, and looking forward to further experimentation. And it's a bit scary how much information you can determine from the device
Mclass
Karl/Mclass
I think I understand the problem now so I'm going to try a different approach. The problem I'd been having was using the result of one dropdown box as the feed for another in the same dialog. I'd coded a patch workaround to make it happen but clearly it's not flexible enough. I think I've a solution that will improve speed and ensure that all possible devices are provided for you to choose from.
I've also had problems setting defaults in text fields before it's presented to the user for completion. Still working on that logic.
Thanks for all of the feedback - I've got a path to resolution now and I'll try to upload a new version tonight.
There are a couple of features I'm leaving until the next main release. Sending push messages to iPhones (BTW it works really well) and Stationary power management. I only left these because I was keen to stabilise the current features before moving on with new ones.
Regards
Mike
