Errors after updating from 0.6.7 to 7.1.8
Fri May 24, 2019 7:43 am
McJohn offline
Karl, version 0.6.7. of SecondsSinceLastChange was working perfectly.
We did an update to version 7.1.8 but then the errors are flying around and it won't work anymore.
what have we done wrong?
secondsSinceLastChange Error Error in plugin execution startup:
File "plugin.py", line 85, in startup
KeyError: key id 784322109 not found in database
secondsSinceLastChange Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 516, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'ML'
secondsSinceLastChange Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
secondsSinceLastChange Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 231, in deviceUpdated
und so weiter ...
Fri May 24, 2019 10:32 am
Re: Errors after updating from 0.6.7 to 7.1.8
looks like you deleted a "secs since last change device" - source while the plugin was inactive.
I need to be home to fix that condition
Fri May 24, 2019 12:31 pm
McJohn offline
Thanks for the feedback.
Strange, I didn't delete any device.
I only double clicked the latest downloaded version of SecondsSinceLastChange and after the install that errors appeared.
After the downgrade to 0.6.7 everything is working normal again. So don't hurry, it's working at the moment.
