SecondsSinceLastChange
Thu Aug 27, 2015 10:40 am
Re: SecondsSinceLastChange
https://www.dropbox.com/s/lnv5r7rpi2v987e/secondsSinceLastChange-v-0-6-2.zip?dl=0v0.6.2
fixed:
had an error in the calculation even as simple as that one was.
Thu Aug 27, 2015 2:34 pm
Shutter offline
Thanks Karl.
Simon
Sat Aug 29, 2015 7:15 am
shapa offline
It works :)
Thank you very much! Very useful plugin.
Wed Dec 09, 2015 12:27 pm
https://www.dropbox.com/s/3ra77sv6zdj32p8/secondsSinceLastChange-v-0-6-5.zip?dl=1v-0-6-5
fixed:
In case you delete a device to be tracked: the plugin now will stop tracking THAT device and remove it from its tracking list. The secondsSince .. variables will not be deleted.
Wed Apr 06, 2016 11:54 am
Asconasny offline
Hi Karl
the plugin seems to loose configuration after some time,
I noticed yesterday that the variables was not updating and the tracking devices was gone from the configuration when i did a print tracking setup , so i configured it again and today its all gone again.
the variables is still there but when i do a print tracking i get:
secondsSinceLastChange Configuration: Dev-Name DevID.... State Parameters ........
No devices..
Will set it up again se what happens..
Regards
Asconansy
Wed Apr 06, 2016 2:30 pm
you should see something like this:
error; device with indigoID = 123456 does not exist, removing from tracking
when it removes a device from tracking, if not .. don't know how they disappear.
I have a small upgrade I will publish tonight.
Wed Apr 06, 2016 3:07 pm
Asconasny offline
Found this in my log:
<type 'exceptions.StandardError'>: ServerCommunicationError -- timeout waiting for response
2016-04-06 08:57:50.481 mqttGateway Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-04-06 08:57:50.481 secondsSinceLastChange error; device with indigoID = 1085070662 does not exist, removing from tracking
Seems when i have this ServerCommunicationError most of my plugins seems to complain.
2016-04-06 15:29:58.329 Smart Devices Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 839, in deviceUpdated
2016-04-06 15:29:58.331 WeatherSnoop Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 454, in runConcurrentThread
2016-04-06 15:29:58.331 WeatherSnoop Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-04-06 15:29:58.332 Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 59, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 388, in runConcurrentThread
2016-04-06 15:29:58.333 Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-04-06 15:29:58.334 fingscan updating ipDevice 09 does not exist , (re)creating
2016-04-06 15:29:58.334 secondsSinceLastChange error; device with indigoID = 775372131 does not exist, removing from tracking
2016-04-06 15:29:58.335 mqttGateway Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 103, in runConcurrentThread
2016-04-06 15:29:58.335 mqttGateway Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-04-06 15:29:58.336 mqttGateway Debug Starting ConcurrentThread ... Active listener threads = 8
2016-04-06 15:29:58.340 fingscan in Line '5213' has error='NameNotUniqueError'
2016-04-06 15:29:58.341 fingscan MAC# A4:5E:60:DC:83:A3
2016-04-06 15:29:58.342 fingscan indigoIpVariableData: {'status': u'up', 'suppressChangeMSG': 'show', 'index': 8, 'nickName': u'Macbook Pro', 'WiFi': u'', 'deviceInfo': u'', 'noOfChanges': 8314, 'ipDevice': '09', 'WiFiSignal': '0', 'hardwareVendor': u'', 'timeOfLastChange': u'2016-04-06 15:11:00', 'usePing': u'', 'ipNumber': u'10.0.1.8', 'variableName': ''}
2016-04-06 15:29:58.342 fingscan allDeviceInfo: {'status': 'up', 'deviceName': u'Macbook Pro', 'devExists': 1, 'suppressChangeMSG': u'show', 'setWiFi': '', 'nickName': u'Macbook Pro', 'WiFi': u'', 'deviceInfo': u'', 'noOfChanges': 8314, 'WiFiSignal': '', 'hardwareVendor': u'\n', 'deviceId': 1238321489, 'timeOfLastChange': '2016-04-06 15:11:00', 'usePing': u'
Any idea whats going on?
Wed Apr 06, 2016 3:12 pm
ok this happens when you mac is overloaded. and the server does not answer. the an error occurs and the plugin thinks that the device has been deleted. and hence removes it.
will try to fix
Wed Apr 06, 2016 3:33 pm
Asconasny offline
Okey, then we have the answer to that :)
Now my next question would be.. Overloaded? why would it be?, i thought indigo didn't use much resources
What kind of mac do i need? this is a I7 2.6 with lots of ram
Could it be the hardrive that can't keep up. thats the original 1tb HD 5400rpm
would a upgrade to SSD be the answer? (I hope so, an excuse to buy one :) )
Or is it something that happens from time to time.
Should i be worried?
regards
Asconasny
Wed Apr 06, 2016 4:05 pm
this is likely not indigo, but one of the plugins that goes off the rails and sends requests/ messages to indigo. then indigo server goes into overload and does not answer
when this happens check activity monitor/ sort cpu time/ click on top cpu user/ and do info/ look at open files. the first line shows the plugin name
Wed Apr 06, 2016 4:09 pm
Do you happen to be running Honeywell thermostat plugin?
That has a leak in it at moment, but Nick is waiting for Honeywell devs to authorise his update using official API.
Wed Apr 06, 2016 4:10 pm
no I have a simple trane
Wed Apr 06, 2016 4:21 pm
https://www.dropbox.com/s/0nwytwfmwkpj6ce/secondsSinceLastChange-v-0-6-6.zip?dl=1
added/fixed:
if indigo runs into timeout, the plugin was removing devices as it thought that they do not exist anymore.
now it will try twice with 1 second wait in-between tries to connect to indigo if the first one fails.
howard that should reduce your problem, if indigo is really bad (> 1 second) it will still remove trackings.
Wed Apr 06, 2016 4:42 pm
Asconasny offline
Im not using Honeywell plugin,
Thanks for the update, your support is amazing :D
I will check the activity monitor if I'm nearby the server when/if it happens again.
Regards
Asconasny
Wed Apr 06, 2016 5:25 pm
v-0-6-7 https://www.dropbox.com/s/nivfqjve2s5pkmk/secondsSinceLastChange-v-0-6-7.zip?dl=1
added an explicit timeout error check, then wait 5 seconds then try again. This is difficult to test as the condition has to occur
