Custom device image stuck in Indigo touch
Forum rules
Thu Apr 11, 2013 6:54 am
scotsman offline
I am trying to use a graphic to represent zone status using JC's Elk M1 plug-in. Each zone is a custom device.
- The states show up correctly in Indigo 6 (Normal, Trouble, Violated etc.)
- The 'Remote Display' checkbox is grayed out.
- The devices do not show in the devices tab in Indigo touch
The only success I have is in the browser control page:
"Zone is violated (true or false)" switching to" true" causes device.png to be replaced with device+on.png in the devices folder. device+true.png or device+Normal.png do not work.
In Indigo touch the image doesn't change. When represented as text, the device state updates correctly.
I presume the problem lies in the device definition in devices.xml file inside the plug in, but not sure where. The definition is below. Any suggestions?
<Device type="custom" id="alarmZone">
      <Name>Alarm Zone</Name>
      <ConfigUI>
         <Field id="zonelabel" type="label">
            <Label>This device type is auto created by the plugin. One device per zone configured on the alarm panel will be created. You should not create devices of this type manually.</Label>
         </Field>
         <Field id="zonelabel1" type="label">
            <Label>If you've added new zones to your alarm system use the menu item "Rescan alarm zones" to create devices for the new zones.</Label>
         </Field>
         <Field id="address" type="textfield" hidden="true">
            <Label/>
         </Field>
         <Field id="type" type="textfield" hidden="true">
            <Label/>
         </Field>
      </ConfigUI>
      <States>
         <State id="status" readOnly="YES">
            <ValueType>
               <List>
                  <Option value="Normal">Normal</Option>
                  <Option value="Trouble">Trouble</Option>
                  <Option value="Violated">Violated</Option>
                  <Option value="Unknown">Unknown</Option>
               </List>
            </ValueType>
            <TriggerLabel>Zone status changed</TriggerLabel>
            <TriggerLabelPrefix>Zone became</TriggerLabelPrefix>
            <ControlPageLabel>Zone status</ControlPageLabel>
            <ControlPageLabelPrefix>Zone is</ControlPageLabelPrefix>
         </State>
      </States>
      <UiDisplayStateId>status</UiDisplayStateId>
   </Device>
Thu Apr 11, 2013 11:26 am
Re: Custom device image stuck in Indigo touch
For Indigo to use the custom image lookup heuristics the base image name needs to have a + character. That tells the Indigo clients to use the more complex lookup technique. So try images named like:
alarmstate+.png    (you probably just want a duplicate of the +Unknown file for this one)
Thu Apr 11, 2013 9:01 pm
scotsman offline
Ahhhh I see. I didn't get that you had to have a base image with the + character. I did read the documentation but didn't catch that. Works a treat - thanks for the quick response as always.
