send variables to python script
Forum rules
This is a legacy forum which is locked for new topics. New topics should be started in one of the other forums under Extending Indigo
Sat Mar 09, 2013 11:15 am
HA1 offline
Is there any way, when executing a python script, that I can access some variable that's sent in via a REST call that executes that action group?
For example, I want to be able to execute
http://indigoserver/actions/myaction?_m ... =somevalue
And then somewhere in a python script for action group "myaction" I want to be able to access that variable's ("variable1") value in my python script. I presume I have access to Indigo variables in python scripts? Even if I do, I'm still not sure how to set an Indigo variable as part of an action group via a REST API parameter.
Thanks in advance for any advice.
Sat Mar 09, 2013 12:59 pm
Re: send variables to python script
You can do it, but it will require more than a single RESTful URL call. You cannot both set an Indigo variable value and execute an Action Group in a single call.
Here is the RESTful call to change an Indigo variable value:
http://127.0.0.1:8176/variables/some_var_name?_method=put&value=somevalue
And here is accessing that value from an Indigo python script:
var = indigo.variables["some_var_name"]   # Instead of a string name try to use the numerical ID for the var
indigo.server.log("value is: " + str(var.value))
