On page http://www.perceptiveautomation.com/wik ... base_class under the Dim and Brighten you show parameters of by and delay. In both sets of examples you use a parameter of to. There is setBrightness that takes a brightness value.
dim does currently take the to parameter. Is the doc incorrect and to is a valid parameter or is the doc correct and to will stop working when you fix the bug?
If to is valid when would I use setBrightness?
Feature or bug? I can issue a dim("A", to=50) for a dimmer that is off and it will brighten it to 50.
Another feature? I can also brighten from 100 to 10.
PS I read the post and I wanted to say I am not trying to be a dick. It does appear the to has been left out as a parameter. But I don't really care how the rest works.
