Reload, enable, disable plugin via trigger action / script?
Forum rules
Wed Jan 02, 2013 8:23 pm
neilgreene offline
Re: Reload, enable, disable plugin via trigger action / scri
Could someone help me with a script that would reload the ELK plugin? Thanks in advance
Thu Jan 03, 2013 10:40 am
Try:
plugin = indigo.server.getPlugin("com.elkplug.indigoplugin.elkm1g")
if plugin.isEnabled():
   plugin.restart()
Wed Mar 20, 2013 11:25 pm
thedon offline
Hello,
I tried to use this script but cannot find the plugin ID for the vera plugin.
Look through documentation but couldn't find a way to get it.
I am going to schedule the plugin to reload every 2 hours as it works but some communication gets lost in the plugin over time I've noticed.
Reloading it show fix this
Thu Mar 21, 2013 5:54 am
Its plugin ID is:
com.homeautomationplugins.vera
Wed May 15, 2013 1:13 am
c64 offline
So the only control over a Plugin is that you can restart it using Python? I am trying to work out how to disable a running Plugin, (then change an .indiPref file outside of Indigo), and then restart the Plugin. Is there a trick to doing that? Thank you.
Thu May 16, 2013 9:15 am
Correct. Out of security/usability concerns we only allow plugins to be restarted (but not started) via scripting.
Perhaps there is another way to accomplish what you need. Can you provide more details on what that is?
