This is a legacy forum which is locked for new topics. New topics should be started in one of the other forums under Extending Indigo
plugin = indigo.server.getPlugin("com.elkplug.indigoplugin.elkm1g")
if plugin.isEnabled():
plugin.restart()
c64 wrote:So the only control over a Plugin is that you can restart it using Python? I am trying to work out how to disable a running Plugin, (then change an .indiPref file outside of Indigo), and then restart the Plugin. Is there a trick to doing that? Thank you.
