About that "state" column...
Forum rules
Fri Sep 16, 2011 12:58 am
Perry The Cynic offline
If I happen to give my device a configuration value called "address", its value shows up in the "address" column in the Devices list. This is very handy (and cool).
So how come if I give my device a state called "state", it doesn't show up in the column labeled "state"? That column is practically jumping up and down begging to be filled...
(And yes, pretty much all my devices have a "state" state - offline, online, failed, whatever.)
Pretty please?
Cheers
-- perry
Fri Sep 16, 2011 8:33 am
Re: About that "state" column...
Inside the Devices.xml just change or add the UiDisplayStateId node to point to the ID of the state you want:
<UiDisplayStateId>playStatus</UiDisplayStateId>
If you need to do it dynamically, then you can override:
def getDeviceDisplayStateId(self, typeId, devId):
Starting in the next beta, it should get called when the plugin dialog closes, right after getDeviceStateList() is called.
Fri Sep 16, 2011 8:38 am
Rather than use a fixed name (like address) for that, you can specify which state is the display state in the device's xml:
   <Device type="custom" id="station">
      <Name>Weather Station</Name>
      <ConfigUI>
         <Field id="host" type="textfield" defaultValue="localhost">
            <Label>Enter a host name or IP:</Label>
         </Field>
         <Field id="port" type="textfield" defaultValue="8000">
            <Label>Enter a port number:</Label>
         </Field>
         <Field id="address" type="textfield" hidden="true">
            <Label/>
         </Field>
      </ConfigUI>
      <UiDisplayStateId>temperatureF</UiDisplayStateId>
      <States>
         <State id="temperatureF">
            <ValueType>Number</ValueType>
            <TriggerLabel>Outdoor Temperature °F</TriggerLabel>
            <ControlPageLabel>Outdoor Current Temperature °F</ControlPageLabel>
         </State>
      </States>
   </Device>
Note the <UiDisplayStateId> element.
Sun Sep 18, 2011 1:41 am
This works great.
-- perry
Mon Sep 19, 2011 10:23 pm
Hm... is there by any chance a UiDisplayAddressId element to determine which config field the address column shows, too? Or is that hard-wired to the address field?
Cheers
-- perry
Tue Sep 20, 2011 6:43 am
Sorry, that one is hardwired to 'address.'
Sun Feb 19, 2012 5:28 am
HomeAutomationPlugins.com offline
I've got a device defined as follows:
    <Device type="dimmer" id="Dimmer">
        <Name>LightwaveRF Dimmer</Name>
        <ConfigUI>
            <Field id="address" type="textfield" defaultValue="192.168.0.220">
            <Label>Wifilink IP Address:</Label>
         </Field>
            <Field id="room" type="menu" tooltip="Room Number" defaultValue="1">
            <List>
               <Option value="1">1</Option>
               <Option value="2">2</Option>
               <Option value="3">3</Option>
               <Option value="4">4</Option>
            </List>
                <Label>Room Number:</Label>
            </Field>
            <Field id="device" type="menu" tooltip="Device Number" defaultValue="1">
            <List>
            </List>
                <Label>Device Number:</Label>
            </Field>
        </ConfigUI>
    </Device>
What I'd really like is to have a string representation of all 3 properties show in the "address" field (at the moment I understand that Indigo is hard coded to read the property with id="address"
So in the above example ideally I'd like the address field to show "192.168.0.220 R1D1" rather than just "192.168.0.220" - with the R1D1 being Room 1 Device 2 from the other two properties.
Is this possible at all?
many thanks,
Sun Feb 19, 2012 11:31 am
If I understand your question correctly, it sounds like you should:
1) Change your current field ID to something like "rawAddress."
2) Add a new field "address" and give it the attribute hidden="true" so it doesn't show in the configuration sheet.
3) Inside your validateDeviceConfigUi() method build the compound address from the rawAddress value and stuff it into the "address" key.
Sun Feb 19, 2012 11:44 am
That's exactly what I want to do!
I'm still getting my head round everything so would you be able to give me a code snippet for (3) above?
Many thanks!
Sun Feb 19, 2012 11:53 am
Below is a good template. It does more than just #3, but is a good example of how the validate method should be used:
      errorsDict = indigo.Dict()
      if False:   # check to see if valudesDict["rawAddress"] is good here
         errorsDict["rawAddress"] = u"IP address entered isn't correct"
      if len(errorsDict) > 0:
      valuesDict["address"] = valuesDict["rawAddress"] + u" R1D1"
      return (True, valuesDict)
Sun Feb 19, 2012 12:03 pm
That's great - thanks!
