Plugin Window Question
Forum rules
Sun Jul 07, 2013 9:36 pm
jd10884 offline
Good day,
I am writing a plugin and the default configure window is too small, is there a way to set the size in the PluginConfig.xml file rather than dragging the corner once it is open?
Thanks in advance
Jeff
Sun Jul 07, 2013 9:40 pm
Re: Plugin Window Question
Hi Jeff,
The window should be sized to fit the controls when it is first shown (Indigo 6 does this, but not v5). Can you take a screen capture or explain the problem in more detail?
To answer your question though, you cannot specify the height/width. In the future the UI might be presented in other clients besides the Cocoa one (Indigo Touch, browser client, etc.), so absolute sizing won't give good results.
