directory of indigo
Forum rules
Thu Jun 13, 2013 11:17 pm
directory of indigo
Is there a variable that contains the directory where indigo is stored. i.e.
/Library/Application Support/Perceptive Automation/Indigo 3 4 5 6
would like to write a file into the script library and don't want to manually change directories when versions change.
thanks
Thu Jun 13, 2013 11:30 pm
Re: directory of indigo
Hi Karl,
No, there isn't. Normally for scripts like that I just have it check multiple folders until it finds one (starting with a high number).
Fri Jun 14, 2013 9:07 am
Another option, if you keep your database file in the Databases folder, is to use this IOM server method to get the full path to the db file:
indigo.server.getDbFilePath()
That will return a string that's the full unix path to the db file - just strip the "Databases/DBNAME.indiDb" off the end and you should have the path to the prefs folder.
Fri Jun 14, 2013 9:17 am
Clever idea, Jay. :-)
Fri Jun 14, 2013 10:59 am
could you translate this into applescript... not at python level yet...
thx
Fri Jun 14, 2013 11:11 am
Sorry, can't be done in AppleScript.
The next release (probably not until after the first of July) will have a method to get the path to the server's install folder (so you won't have to chop off the database specific bits).
[EDIT] which will still be Python only. We're not enhancing AppleScript (since Indigo 5).
