iTunes 11.03
Forum rules
Tue May 28, 2013 4:58 pm
rszmetro offline
iTunes 11.03
hi,
I upgraded to iTunes 11.03 and my iTunes plugin isn't woking. Says it is for Indigo 6 and I am using Indigo 5. What should I do to fix it?
Rob
Rob Z
Tue May 28, 2013 5:12 pm
Re: iTunes 11.03
Right - Apple changed how the communication works with iTunes 11. It's been fixed in the Indigo 6 beta.
Tue May 28, 2013 5:33 pm
rszmetro offline
Re: iTunes 11.03
Do I need to go to Indigo 6?
Rob Z
Tue May 28, 2013 5:41 pm
Re: iTunes 11.03
We don't have any plans to back port iTunes 11 compatibility to Indigo 5 so if you want to use it with the plugin then yes.
Tue May 28, 2013 5:44 pm
rszmetro offline
Re: iTunes 11.03
OK, thanks, I'll do the upgrade.
Rob
Rob Z
Tue May 28, 2013 5:52 pm
rszmetro offline
Re: iTunes 11.03
Sorry to be a bother - Smartphone Radar plugin now not working with Indigo 6:
File "plugin.py", line 86, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 428, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 107, in indigoVersionIsAtLeast
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: '0 b8'
Rob Z
Tue May 28, 2013 5:56 pm
rszmetro offline
Re: iTunes 11.03
I also seem to have lost the extended NOAA plugin that provided next seven days forecasts.
Rob Z
Tue May 28, 2013 6:33 pm
Re: iTunes 11.03
Hi Rob,
Re-install the latest versions of those plugins and I believe they will work correctly.
And thanks for the upgrade purchase!
