Device selection order
Forum rules
This is a legacy forum which is locked for new topics. New topics should be started in one of the other forums under Extending Indigo
Tue Jan 15, 2013 1:24 am
berkinet offline
Is there a way to control the order a plugin's devices appear in the device selection popup menu? If the only way is via the ASCII sort sequence, what are the rules on device naming?
Tue Jan 15, 2013 7:50 am
Re: Device selection order
They are sorted by name only. Devices should be able to have arbitrary string names as long as they have legal character encodings.
You might want to use folders though instead for organization. Plugins can create folders and move devices they create/own into those folders:
newFolder = indigo.devices.folder.create("myPluginFolderName")
indigo.device.moveToFolder(dev1, value=newFolder)
indigo.device.moveToFolder(dev2, value=newFolder)
indigo.device.moveToFolder(dev3, value=newFolder)
indigo.device.moveToFolder(dev4, value=newFolder)
Tue Jan 15, 2013 11:00 am
berkinet offline
Matt: Sorry if I wasn't clear. I was referring to the popup list of Device types that is presented in the Device ConfigUI. The list drawn from the id parameter in the Device tags in Devices.xml.
I would like to control the order the types are presented.
Tue Jan 15, 2013 11:15 am
Are you referring to the device type shown in the main Device dialog (before the plugin config UI dialog is shown)?
I don't recall how that works -- is it currently sorting alpha numerically versus the order of definition in the XML file?
Tue Jan 15, 2013 11:27 am
berkinet offline
Yes. To be more accurate, it is the model. As in...
It appears to be an alpha sort on the Device's id parameter. It also appears that the character set is restricted. Starting the id with characters like • to force a sort order throws errors.
Tue Jan 15, 2013 3:34 pm
It's alphabetical by type name (not id). I inserted a bullet and it worked fine - what was the error it threw?
Tue Jan 15, 2013 3:47 pm
berkinet offline
Sorry, I was unclear. The error is thrown when the device is queried.
So, this...
<Device id="ifKit" type="custom" >
      <Name>•Phidgets Interface Kit</Name>
results in this...
>>> print indigo.devices[1267280394]
  File "<console>", line 1, in <module>
UnicodeEncodeError: 'ascii' codec can't encode character u'\u2022' in position 1788: ordinal not in range(128)
Tue Jan 15, 2013 4:13 pm
That's because the python "print" statement tries to use str() on the value - which won't work because the bullet is a unicode character.
Tue Jan 15, 2013 4:16 pm
berkinet offline
So, I can use characters like •, ≥, etc. to "force" a sort order, but, I wouldn't be able to print them out easily (like for testing, etc.).
Sounds like it isn't worth it, and would certainly confuse others don the road.
Thanks.
Tue Jan 15, 2013 4:33 pm
Yep - using odd characters to force sort order is rarely a good idea.
Tue Jan 15, 2013 4:40 pm
berkinet offline
Agreed. So, could you throw this into the circular file of someday features... a Device model tag <Sort> if it existed, the contents would be used to create the sort, following the same rules used for <Name>. If it did not exist, then Sort would = Name.
So, I could code:
      <Name>Phidgets Interface Kit</Name>
                <Sort>1</Sort>
Tue Jan 15, 2013 5:11 pm
Ok - after some investigation (because this sounded familiar), I've found that unlike the events and actions, we are sorting the device types based on the device type name (as identified above). Not sure why we did that exactly (probably had some reason), but we can't remember why.
It seems like the better idea is to allow the device types to be sorted by the order they are declared in the XML just like we do events and actions. So we'll make that change in the next release unless someone has a problem with it.
Tue Jan 15, 2013 5:16 pm
berkinet offline
Great. No objection here,
Thanks.
Wed Jan 16, 2013 1:32 am
nsheldon offline
I object!! :twisted:
/me trolling
(I don't actually object).
Fri Jan 25, 2013 3:34 am
The next beta of Indigo 6 is available which maintains the order defined in the XML.
