SEN.SE pausing my API subscriptions
Tue Jul 12, 2016 9:14 pm
SHKnapp offline
Hey Karl,
I've messed something up. I've had this working for months, but now I'm getting loads of emails from sen.se with the following:
Your subscriptions have been paused
Hello Spencer!
We noticed that one or more of your subscriptions do not work properly. Indeed we could not notify the following URLs :
kw123 (http://76.**.**.***:8080)
These subscriptions have been paused. You can unpause them by clicking on the button below.
Manage my subscriptions
I've tried to:
6. reset ALL and resync with SEN.SE for PULL and PUSH mode
unfortunately this didn't fix the problem. I tried to create a new database and set everything up again, but when I created a new database in Indigo all my mother data was reimported... I guess it's stored separately and the plugin happily pulled it in.
any suggestions?
thanks,
Spencer
Wed Jul 13, 2016 1:49 am
Re: SEN.SE pausing my API subscriptions
Check the userid pass words port and ip numbers in config
Then check documents/mother/ we server.log.
If you want to delete things then delete the mother/ cookie directory in documents
Wed Jul 13, 2016 1:51 am
And yes Sen.se will continue to send these emails. That's new. Without stopping.
You can go to the webpage user developer subscriptions and delete the subscription
Wed Jul 13, 2016 10:11 pm
SHKnapp offline
in config where? I don't see any fields that look like that in the plugin->configure
I only have:
API Key
Unit for Temp
define PUSH/PULL mode
debug
I did do the following...
disable plugin
move documents/mother to motherSafe
relaunched indigo and enabled plugin
I was surprised to see that things started to reappear...
I guess the comfit file for the plugin st stored somewhere else.
anyway, the devices are all back in indigo and I'll see if I start getting more emails
I did log into the developer page and clicked on subscriptions I didn't see any that I could delete
There was a way for me to add new subscriptions
I feel like I failing on every suggestion you have... sorry about that.
Wed Jul 13, 2016 10:54 pm
here the menu. which version are you using?
The cookies get automatically regenerated by asking sen.se why you have registered- that is done outside push mode.
Then once we get that info ONE subscription is setup to receive ALL cookie data.
Make sure that on your router your ip/port is forwarded if you use PUSH mode.
Screen Shot 2016-07-13 at 23.49.09.png (58.28 KiB) Viewed 3711 times
Thu Jul 14, 2016 1:04 am
SHKnapp offline
I'm definitely not seeing that menu.
I'm missing everything between
define push / pull mode
and
debug
The plugin menu says:
About mother v1.4.1...
I even tried to reinstall but indigo gave me a warning that I'm already running that version
Thu Jul 14, 2016 6:21 am
1.4.1 is the latest version.
that part should show up when you select PUSH mode.
