Will this plugin be upgraded so it can be used in Indigo version > v2022.2?
Kind regards, Gerrit Jan
no debug
Stopping plugin arduino (pid 6352)
arduino in Line '1044' has error='None'
arduino in Line '326' has error=''NoneType' object has no attribute '__getitem__''
arduino stopping plugin
Stopped plugin arduino
Upgrading plugin arduino to newer version 2022.9.11 (previous version moved to trash)
Loading plugin "arduino 2022.9.11" using API v3.0.0
Starting plugin "arduino 2022.9.11" (pid 42670)
Started plugin "arduino 2022.9.11"
arduino ARDUINO --V 2022.9.11 initializing
arduino connection to arduino >arduino_balkon< has error=''Response' object has no attribute 'read''
arduino connection to arduino >arduino_schuur< has error=''Response' object has no attribute 'read''
arduino init done
Trigger arduino_schuur lost connection
arduino arduino_schuur; current status is: Offline (test2)
arduino module 'sys' has no attribute 'exc_traceback'; line#,Module,Statement:(543, 'setArduinoStatesValues', 'self.myLog(255, u" error updating Pin state cmdValue " + Pin + " " + str(state) + " " + str(cmdValue) + " l \'%s\', e:\'%s\'" % (sys.exc_traceback.tb_lineno, e))')
arduino arduino_balkon; current status is: Offline (test2)
Schedule arduino_schuur_cmd ALL_Sensors
Schedule arduino_balkon_cmd ALL_Sensors
debug all
Stopped plugin "arduino 2022.9.11"
Starting plugin "arduino 2022.9.11" (pid 42691)
arduino deviceStartComm for arduino_balkon
arduino device :arduino_balkon in deviceStartComm refreshing props :com.karlwachs.arduino : (dict)
IPNumber : 192.168.178.22 (string)
Pin_A0 : OFF (string)
Pin_A1 : OFF (string)
Pin_A2 : OFF (string)
Pin_A3 : OFF (string)
Pin_A4 : OFF (string)
Pin_A5 : OFF (string)
Pin_D0 : OFF (string)
Pin_D1 : OFF (string)
Pin_D2 : OFF (string)
Pin_D3 : O (string)
Pin_D4 : OFF (string)
Pin_D5 : OFF (string)
Pin_D6 : OFF (string)
Pin_D7 : OFF (string)
Pin_D8 : OFF (string)
Pin_D9 : OFF (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S10 : OFF (string)
Pin_S11 : OFF (string)
Pin_S12 : OFF (string)
Pin_S13 : OFF (string)
Pin_S14 : OFF (string)
Pin_S15 : OFF (string)
Pin_S16 : OFF (string)
Pin_S17 : OFF (string)
Pin_S18 : OFF (string)
Pin_S19 : OFF (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
Pin_S6 : I (string)
Pin_S7 : OFF (string)
Pin_S8 : OFF (string)
Pin_S9 : OFF (string)
UpdateFrequency : 10 (string)
address : 192.168.178.22 (string)
maxNofpinsPerMessage : 20 (string)
suppressOfflineMessages : 0 (string)
urltimeout : 5 (string)
arduino deviceStartComm for arduino_schuur
arduino device :arduino_schuur in deviceStartComm refreshing props :com.karlwachs.arduino : (dict)
IPNumber : 192.168.178.21 (string)
Pin_D3 : OFF (string)
Pin_D5 : O (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
Pin_S6 : OFF (string)
address : 192.168.178.21 (string)
arduino looping to check devices for updates:
arduino i, out 0 ['st']
arduino http://192.168.178.22/?st&?
arduino http://192.168.178.21/?st&?
arduino init done
arduino i, out 0 ['st:']
arduino http://192.168.178.22/?st:&?
arduino i, out 0 ['pg:D0=U', 'pg:D1=U', 'pg:D2=U', 'pg:D3=O', 'pg:D4=U', 'pg:D5=U', 'pg:D6=U', 'pg:D8=U', 'pg:D9=U']
arduino http://192.168.178.22/?pg:D0=U&pg:D1=U&pg:D2=U&pg:D3=O&pg:D4=U&pg:D5=U&pg:D6=U&pg:D8=U&pg:D9=U&?
arduino i, out 0 ['aw:S0=ALL_Sensors']
arduino http://192.168.178.22/?aw:S0=ALL_Sensors&?
arduino http://192.168.178.21/?st:&?
arduino i, out 0 ['pg:D0=U', 'pg:D1=U', 'pg:D2=U', 'pg:D3=U', 'pg:D4=U', 'pg:D5=O', 'pg:D6=U', 'pg:D8=U', 'pg:D9=U']
arduino http://192.168.178.21/?pg:D0=U&pg:D1=U&pg:D2=U&pg:D3=U&pg:D4=U&pg:D5=O&pg:D6=U&pg:D8=U&pg:D9=U&?
debug all
Stopping plugin arduino (pid 44937)
arduino in Line '375' has error='argument of type 'NoneType' is not iterable'
arduino device :arduino_balkon in deviceStopComm
arduino device :arduino_schuur in deviceStopComm
Upgrading plugin arduino to newer version 2022.9.12 (previous version moved to trash)
Loading plugin "arduino 2022.9.12" using API v3.0.0
Starting plugin "arduino 2022.9.12" (pid 44945)
Started plugin "arduino 2022.9.12"
arduino ARDUINO --V 2022.9.12 initializing
Pin_D3 : O (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
Pin_S6 : I (string)
Pin_D5 : O (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
arduino connection to arduino >arduino_balkon< has error='can only concatenate str (not "bytes") to str'
arduino connection to arduino >arduino_schuur< has error='can only concatenate str (not "bytes") to str'
arduino init done
arduino i, out 0 ['rd:S1', 'rd:S2', 'rd:S3', 'rd:S4', 'rd:S5', 'rd:S6']
arduino http://192.168.178.22/?rd:S1&rd:S2&rd:S3&rd:S4&rd:S5&rd:S6&?
Schedule test batterylevel regenmeter
arduino setPin data: arduino_schuur deviceTypeId:UNO {'UNO': 'arduino', 'MEGA': 'arduino', 'mkr1000': 'arduino', 'FREEE-Undefined': 'arduino', 'ESP16': 'arduino', 'ESP1': 'arduino', 'sainsmart8-1': 'sainsmart'}
arduino action= aw:S0=ALL_Sensors&
arduino hello 1
arduino http://192.168.178.21/?aw:S0=ALL_Sensors&?
arduino error updating Pin state cmdValue Pin_D5 rampDown:1000,0,255 ['analogWrite', '1000,0,255']
arduino Error
File "plugin.py", line 537, in setArduinoStatesValues
cmdValue[1] = cmdValue.split(",")[1]
AttributeError: 'list' object has no attribute 'split'
arduino returned= {'Status': 'Offline'}
arduino setPin data: arduino_balkon deviceTypeId:UNO {'UNO': 'arduino', 'MEGA': 'arduino', 'mkr1000': 'arduino', 'FREEE-Undefined': 'arduino', 'ESP16': 'arduino', 'ESP1': 'arduino', 'sainsmart8-1': 'sainsmart'}
arduino hello 1
arduino Error
arduino Error
debug all
Reloading plugin "arduino 2022.9.13" using API v3.0.0
Stopping plugin "arduino 2022.9.13" (pid 45362)
Stopped plugin "arduino 2022.9.13"
Starting plugin "arduino 2022.9.13" (pid 45365)
Started plugin "arduino 2022.9.13"
arduino ARDUINO --V 2022.9.13 initializing
Pin_D3 : O (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
Pin_S6 : I (string)
Pin_D5 : O (string)
Pin_S0 : O (string)
Pin_S1 : I (string)
Pin_S2 : I (string)
Pin_S3 : I (string)
Pin_S4 : I (string)
Pin_S5 : I (string)
arduino msg from arduino: b'>>Configured'
arduino Error
File "plugin.py", line 1016, in sendMsgToArduino
output = self.parseFromArduino(ret,output)
File "plugin.py", line 1063, in parseFromArduino
out= output
NameError: name 'output' is not defined
arduino Error
out= output
arduino init done
arduino Error
out= output
arduino msg from arduino: b'>>pg:D0=U&pg:D1=U&pg:D2=U&pg:D3=O&pg:D4=U&pg:D5=U&pg:D6=U&pg:D8=U&pg:D9=U&'
arduino Error
out= output
arduino msg from arduino: b'>>aw:S0=ALL_Sensors&'
arduino Error
out= output
arduino Error
out= output
arduino msg from arduino: b'>>pg:D0=U&pg:D1=U&pg:D2=U&pg:D3=U&pg:D4=U&pg:D5=O&pg:D6=U&pg:D8=U&pg:D9=U&'
arduino Error
out= output
arduino i, out 0 ['aw:D5=0', 'aw:S0=ALL_Sensors']
arduino http://192.168.178.21/?aw:D5=0&aw:S0=ALL_Sensors&?
arduino msg from arduino: b'>>aw:D5=0&aw:S0=ALL_Sensors&'
arduino Error
out= output
arduino hello 1
arduino hello 1
