ARDUINO DOWNLOAD
Tue Jan 07, 2020 8:18 pm
Re: ARDUINO DOWNLOAD
posted v 7.9.10
fixed "key error mrk1000"
now on plugin store w link to GitHub for plugin source
Thu Jan 16, 2020 9:49 pm
posted v 7.9.11
fixed "bad indent line 35"
Fri Feb 21, 2020 7:11 am
slackman1 offline
Re: ARDUINO DOWNLOAD -> where is arduino.ino sketch?
Hi Karl,
Can't seem to find the arduino.ino sketch in the downloaded zipfile, also checked older downloads...
Thanks for your help.
Best regards, Gerrit Jan
Fri Feb 21, 2020 11:46 am
ARDUINO DOWNLOAD
Thu Jan 27, 2022 12:49 pm
wackena offline
I got the Arduino Plugin connected to Arduino ESP16 board. Indigo can read sensor value from Arduino. Can Indigo write sensor values to Arduino? I'm using a z-wave temp sensor on Indigo and want to. display on Arduino TM1637 digital display. If possible, please advise.
Thu Feb 03, 2022 2:32 am
the plugin can send commands to the arduino to set GPIOs up / down, amps up down, pulse etc.
you could use that to send other data, but then you will need to really change the receiving pgm on the arduino.
Fri Feb 04, 2022 5:53 am
wackena offline
I have a Fibaro FGBS-222 smart implant (z-wave) connected to DHT-22 Temp/Humidity device. Because the smart implant does not auto update Temp and Humidity values to Indigo app, I used a "Schedule" to set frequency to "send update request".
This code send temperature value to IndigoArduino script and is displayed on a TM1637.
import time
indigo.device.statusRequest(552277016) #DHT-22 Temperature
indigo.device.statusRequest(1982059710) #DHT-22 Humidity
time.sleep(1)
tempDev = indigo.devices[552277016].states["sensorValue"] # "055 - Sensor 1"
humidDev = indigo.devices[1982059710].states["sensorValue"] # "055 - Sensor2"
Fahrenheit = round((tempDev * 1.8) + 32,1)
indigo.variable.updateValue(85670234, value=unicode(Fahrenheit))
tempSensor = indigo.variables[85670234]
if tempSensor > 0:
        sensorLog = "OK"
indigo.server.log("Updated varibale tempVar to "+str(tempDev) +" ºC - " + str(round(Fahrenheit,1)) + " ºF - "+sensorLog+" - Humidity - "+str(humidDev)+"%")
plug = indigo.server.getPlugin("com.karlwachs.arduino")
plug.executeAction("setPins" ,  #send temp value to IndigoArduino script
   props ={
    "CMD":"analogWrite"
   ,"Pin" :"D3"
   ,"aValue": tempDev  # DHT-22 temp value
   ,"device": "Arduino Test"}  # indigo  device name
Sun Feb 06, 2022 7:39 pm
reugster offline
Ive tried the links in these messages but cannot find the arduino.ino file. The only thing i ever get is the plugin and i cant find the .ino file anywhere.
Robert
Mon Feb 07, 2022 2:55 pm
arduino.ino file(s) are in first post in https://forums.indigodomo.com/viewtopic.php?f=178&t=14043 ~ 20 lines from top
Mon Feb 07, 2022 5:03 pm
reugster offline
Well, I figured out the problem, the instructions say arduino.ino but the file in the links is indigo.ino
Ive been looking for arduino.ino the whole time..
Setup Steps:
0.You must download the arduino.ino sketch attached in the zip file to your UNO/MEGA+ethernet/WIFI or ESP board . .. and set the proper IP number (and MAC# for ethernet) and or Wifi SSID/password in the sketch
Sun Jun 25, 2023 10:35 am
added features / changes in v2022.9.11 @ 2023-06-25
1. converted code to py3
replaced urllib with requests, changed exceptions
it compiles and runs, but not tested.
Mon Jun 26, 2023 10:18 am
added features / changes in v2022.9.12 @ 2023-06-26
fixed some execption handling and read http response
Thu Aug 03, 2023 2:43 am
dded features / changes in v2022.9.16 @ 2023-08-03
1.  added in parse from arduino:
  - response from arduino; b’>>rd:S1=xxx&rd:S2=xxx& … &S7=xxx’  in python3
  - remove b (byte indicator)
  - remove >> at beginning of string
  - use last 2 char for command id as all cmds are only 2 char long.
2. reduced the error log dump when connection to arduino fails.
