ARDUINO plugin discussion
Wed Oct 05, 2016 8:39 am
Re: ARDUINO plugin discussion
if you want to add special treatment of eg A1 pin (do the 1023 -val: thing)
                                    int val = analogRead(pin);
                                    if (pin ==1){  val=1023 - val}
                                    #if defined(DEBUG)
                                    Serial.print("command = A-read - "); Serial.println(val);
                                    #endif
                                    out+="rd:A"+String(pin)+'='+String(val)+'&';
                                    return;
in the analog pin read section
Thu Oct 06, 2016 12:55 am
Sam offline
Ok, thanks!
/Sam
Thu Oct 06, 2016 11:51 am
yassi offline
Back online, after waiting for a week for the router...
I've tried to upload the modified sketch (discussed here before on Sep. 30, 2016) for the NodeMCU, I have some communication errors.
Can one have a look please?
Arduino: 1.6.11 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Yasmin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Yasmin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Yasmin\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=9600,FlashSize=4M3M -ide-version=10611 -build-path C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Yasmin\Desktop\indigo_Wlan_290916_final_ohne_Ethernet\indigo_Wlan_290916_final_ohne_Ethernet.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Yasmin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Yasmin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Yasmin\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=9600,FlashSize=4M3M -ide-version=10611 -build-path C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Yasmin\Desktop\indigo_Wlan_290916_final_ohne_Ethernet\indigo_Wlan_290916_final_ohne_Ethernet.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClient.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiServer.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\Documents\Arduino\libraries\OneWire\OneWire.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp.o"
Compiling libraries...
Compiling library "ESP8266WiFi"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClient.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClientSecure.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiServer.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiUdp.cpp.o
Compiling library "OneWire"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\OneWire\OneWire.cpp.o
Compiling library "DallasTemperature"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\DallasTemperature\DallasTemperature.cpp.o
Compiling core...
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont.S.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont_util.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_eboot_command.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_flash_utils.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_i2s.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_noniso.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_phy.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_postmortem.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_si2c.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_timer.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_analog.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_digital.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pulse.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pwm.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_shift.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\heap.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libc_replacements.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\time.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\uart.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cdecode.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cencode.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_cache.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_check.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_gc.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_hydrogen.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_nucleus.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\umm_malloc\umm_malloc.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Esp.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\FS.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\HardwareSerial.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\IPAddress.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\MD5Builder.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Print.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Schedule.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Stream.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\StreamString.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Tone.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Updater.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WMath.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WString.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\abi.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\base64.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cbuf.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_main.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\debug.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\pgmspace.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_api.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_hal.cpp.o
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont.S.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont_util.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_eboot_command.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_flash_utils.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_i2s.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_noniso.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_phy.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_postmortem.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_si2c.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_timer.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_analog.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_digital.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pulse.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pwm.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_shift.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\heap.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libc_replacements.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\time.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\uart.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cdecode.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cencode.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_cache.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_check.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_gc.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_hydrogen.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_nucleus.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\umm_malloc\umm_malloc.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Esp.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\FS.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\HardwareSerial.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\IPAddress.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\MD5Builder.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Print.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Schedule.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Stream.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\StreamString.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Tone.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Updater.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WMath.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WString.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\abi.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\base64.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cbuf.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_main.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\debug.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\pgmspace.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_api.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_hal.cpp.o"
Linking everything together...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -g -w -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static "-LC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lib" "-LC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/ld" "-Teagle.flash.4m.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy  -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.elf" -Wl,--start-group "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClient.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClientSecure.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiServer.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiUdp.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\OneWire\OneWire.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\DallasTemperature\DallasTemperature.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" -lm -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lcrypto -lmain -lwps -laxtls -lsmartconfig -lmesh -lwpa2 -llwip_gcc -lstdc++ -Wl,--end-group  "-LC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe" -eo "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/bootloaders/eboot/eboot.elf" -bo "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin" -bm dio -bf 40 -bz 4M -bs .text -bp 4096 -ec -eo "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.elf" -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi  wird verwendet
Bibliothek OneWire in Version 2.3.2 im Ordner: C:\Users\Yasmin\Documents\Arduino\libraries\OneWire  wird verwendet
Bibliothek DallasTemperature in Version 3.7.6 im Ordner: C:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature  wird verwendet
Der Sketch verwendet 239.729 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 1.044.464 Bytes.
Globale Variablen verwenden 33.396 Bytes (40%) des dynamischen Speichers, 48.524 Bytes f¸r lokale Variablen verbleiben. Das Maximum sind 81.920 Bytes.
C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd nodemcu -cb 9600 -cp COM3 -ca 0x00000 -cf C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to nodemcu
   setting baudrate from 115200 to 9600
   setting port from COM1 to COM3
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   espcomm_upload_mem
   setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
   flush start
   setting serial port timeouts to 1 ms
   flush complete
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
   read 0, requested 1
trying to connect
   flush start
   flush complete
   espcomm_send_command: receiving 2 bytes of data
Uploading 243872 bytes from C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin to flash at 0x00000000
   erasing flash
   size: 03b8a0 address: 000000
   first_sector_index: 0
   total_sector_count: 60
   head_sector_count: 16
   adjusted_sector_count: 44
   erase_size: 02c000
   setting serial port timeouts to 15000 ms
   writing flash
   wrote 992, requested 1072
error: failed sending 1072 bytes
.   wrote 992, requested 1044
error: failed sending 1044 bytes
.   wrote 992, requested 1040
error: failed sending 1040 bytes
.   wrote 992, requested 1069
error: failed sending 1069 bytes
.   wrote 992, requested 1073
error: failed sending 1073 bytes
.   wrote 992, requested 1064
error: failed sending 1064 bytes
   read 0, requested 1
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x04
closing bootloader
   flush start
   flush complete
error: espcomm_upload_mem failed
Thu Oct 06, 2016 4:03 pm
try different baud rate (not 9600.. i believe the esp default is 1xxxxx > 100k
Sat Oct 08, 2016 11:41 am
yassi offline
Karl thx.
Well, I'm so disappointed for the moment... :cry:
I was able to upload the sketch with 115k, while uploading the board was flashing, had no errors.
Thought the code was on it, but the board wasn't visible on my WiFi.
Then, re-tried to upload the sketch, since then I am not able anymore to upload something. Also tred another sketch (sned temp to the MQTT broker).
Connection is ok, speed too, board is recognized in Arduino IDE. Tried different COM ports, no chance.
Can't upload.
Also tried to reset the board (push FLASH button while pushing the RESET one), board blinks, but can't upload.
Attached the error codes (only the part with the errors)
Any idea what to do?
@Ross: you are using NodeMCU, can you help, please?
Der Sketch verwendet 237.041 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 1.044.464 Bytes.
Globale Variablen verwenden 33.072 Bytes (40%) des dynamischen Speichers, 48.848 Bytes f¸r lokale Variablen verbleiben. Das Maximum sind 81.920 Bytes.
C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM3 -ca 0x00000 -cf C:\Users\Yasmin\AppData\Local\Temp\build665457cce46db348b64e97e2e10523e7.tmp/NodeMCU_MQTT_DS18B20.ino.bin
   setting baudrate from 115200 to 115200
   espcomm_upload_file
   espcomm_upload_mem
opening bootloader
resetting board
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
Uploading 241184 bytes from C:\Users\Yasmin\AppData\Local\Temp\build665457cce46db348b64e97e2e10523e7.tmp/NodeMCU_MQTT_DS18B20.ino.bin to flash at 0x00000000
   erasing flash
   size: 03ae20 address: 000000
   total_sector_count: 59
   adjusted_sector_count: 43
   erase_size: 02b000
   read 0, requested 1
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
closing bootloader
   flush start
   flush complete
Beim Hochladen des Sketches ist ein Fehler aufgetreten
Sat Oct 08, 2016 11:46 am
Re: ARDUINO plugin discussion
If the upload has no errors then the upload worked
If wifi is not active likely there are some wrong settings.
Will look at the error later.
Sat Oct 08, 2016 12:16 pm
yassi offline
kw123 wrote:
Will looks at the error later.
Ok, thanks!
But as I said, I am not able to upload another sketch too. Same errors.
Sat Oct 08, 2016 11:52 pm
Yassi, remembering your windows setup.. the setup need to get tuned . either move the arduino IDE to the MAC or have a better interface MAC--> WINDOWS where all keys work to see what the issues are .
BUT I do remember that the NODEMCU had problems with the chip they used for USB . I needed to down load a version from some wild Chinese website and it crashed my mac ..
I am not sure if you want to spend a lot more time on the NODEMCU. There are many alternatives with better USB integration and they work on the MAC too.
Sun Oct 09, 2016 3:21 am
yassi offline
Karl, that's true, the only reason I use Windows here is, it's a small PC, have no other use at the moment for it, and it's good in the workshop.
These NodeMCU's are tricky, but I wanted to have some cheap thing to build the sensors (already runnnig at 5V, small, etc.).
But what do you suggest? HUZZZAH, or which ones? They are more expensive as the NodeMCU (got it for 6€)
Thu Oct 20, 2016 1:41 am
Sam offline
I have a problem with my outputs via two relay cards (2x8 relays from the pin 34-49) where the relays are activated with low signal from the Arduino Mega Digital pins. The problem is when Arduino start or restart to pull all the relays for about 1 second and then return to normal. How can I avoid this during start up?
The voltage to the relay coils are fed from an external 5VDC 3A.
Thanks in advance.
/Sam
Thu Oct 20, 2016 6:30 am
srkinard offline
Thanks in advance.
/Sam
Switch the relay wiring...
You want your load wiring to be ON when the relay is energized (HIGH)...
So input goes to COM, and outputs are labeled NO# or NC#....Normally Open or Normally Closed.
Normally Open sounds like what you want...meaning when the Arduino signal is dead/off/low the relay is OPEN and no current will flow...so a reboot won't turn things on by dropping the signal low and allowing the relay to go into CLOSED mode and passing the load current through.
Hope that makes sense.
Thu Oct 20, 2016 10:22 am
I believe skinard is correct.
In addition:
The outputs of the arduino at start are "open" neither low nor high. They do not drive any current, hence the relays are in their "natural" state when the arduino boots.
An issue occurs when you want to have an ON state uninterrupted. i.e. when the arduino boots.
I don't know how to do that. If there is no current / power the relays will be in the normal "OFF" state for a period of time.
Thu Oct 20, 2016 11:15 pm
Sam offline
Ok, thanks to both of you. Then I think I understand.
/Sam
Thu Dec 29, 2016 12:38 am
dawson1331 offline
What are the conditions that cause the message: "Arduino; current status is: Offline (test2)" ? It seems to be some kind of timing issue. I have tried various combinations of the Update frequency and Time out options, etc. but that doesn't seem to make a difference.
BTW I love this plug-in!
Bill
