Latest Software for Fibaro RGBW Controller -Updated 26/07/15
Sun Jun 28, 2015 11:23 am
Chameleon offline
Latest Version of Fibaro RGBW Controller Manager
This plugin is design to provide additional functionality for users of the Fibaro RGBW Controller http://www.vesternet.com/z-wave-fibaro-rgbw-controller. Please read the Use Case post http://forums.indigodomo.com/viewtopic.php?f=176&t=14329 for more details on the Fibaro RGBW Module.
The latest version of Fibaro Light Manager 0.1.15 can be downloaded from the link below:
https://www.dropbox.com/s/dayo30alpcx8lki/Fibaro%20RGB%20Lights.zip?dl=0
You should download this file and install the plugin in the normal way by clicking on the downloaded file.
To use preset colours you also need to download this file:
https://www.dropbox.com/s/yo5k3ucwibakfp9/RGBColours.zip?dl=0
This text file contains the definitions for around 100+ different colours and is required to use any preset colours. The plugin will report an error if this file is not saved in the correct location.
Once downloaded - please copy the file to /Library/Application Support/Perceptive Automation/Indigo 6/Preferences/Plugins folder. I'll automate this in future releases.
You should read the instructions in the FAQ post http://forums.indigodomo.com/viewtopic.php?f=176&t=14350 to help you get started. Please enjoy
This is an Alpha package at the moment that I will be refining over the coming weeks in the same way I did with the NEST Home plugin. Although you can expect some issues I don't expect that they will impact your indigo system but as usual the risk you take by installing an Alpha is your own :D
Notes for version 0.1.15
Corrected an error in the set up code which caused the plugin to fail with a <TypeError>. This was caused by a simple logic error where I had assumed that Composite would be in the device name which is completely wrong :oops: I've now discovered a much better way of finding the core device 'Composite' and you can use any name you like in the Device Name :D
Regards
Mike
