Changing Device Group to Colour doesn't work first time
Tue Apr 18, 2017 6:50 am
petematheson offline
So I have an action group set to set one set of Fibaro RGBW's to a specific colour, and another to 'Switch off LED and linked groups'.
When I switch on the lights, they go to white. Then when I run the same action group again THEN it sets to the right colour.
So I've worked around this by duplicating the colour setting and delaying it by 1 second in the action group. But is it possible to get this bug ironed out somehow, or have I got my settings in a muddle somewhere?
Tue Apr 18, 2017 7:40 pm
Re: Changing Device Group to Colour doesn't work first time
Sounds like a firmware buglet in the Fibaro itself, since Indigo is sending the exact same Z-Wave commands the second time as it does the first time. I think your workaround is going to be the best approach, although it is possible Fibaro has a more recent firmware version that fixes this problem. Not sure what the odds are of that.
Wed Apr 19, 2017 7:22 am
Thanks Matt, I guess I'll have a play to see what I can do. The other modules in the house work ok with similar logic behind them so perhaps it is firmware related.
