WUnderstation Plugin Updates
Mon Jun 01, 2015 6:34 pm
WUnderstation Plugin v0.1.01 is now available
All users of the plugin should apply this update.
  • Code refinements.
  • Fixes bug in refresh interval where (under certain circumstances) the interval was doubled.
  • Fixes bug in URL parameters for multiple-sensor values (temperature, soil temperature, soil moisture, leaf wetness)
Thanks to Aaron for helping to track down several of the gremlins fixed in this update.
Dave
You can download the plugin here.
Fri Aug 28, 2015 8:09 am
Re: WUnderstation Plugin Updates
WUnderstation Plugin v0.1.03 is now available
  • Increases compliance with PEP8.
  • Fixes bug in air quality variable 'PM10 mass'.
Thu Dec 03, 2015 8:02 pm
WUnderstation Plugin v0.2.01 is now available
  • Moves plugin to use subprocess.popen() method over urllib2 and socket for data uploads.
  • Pre-v1.0 production release.
  • Code Maintenance
This will likely be the last update before I take this one out of beta.
Dave
Thu Apr 07, 2016 9:05 am
WUnderstation Plugin v0.2.02 is now available
  • Ensures that devices are not restarted unecessarily.
  • Adds error message screens to plugin configuration dialog.
  • Adds plugin version number to identifier sent to WU.
  • Reverts back to urllib2 and socket.
  • Fixes bug where loading the plugin configuration dialog could cause some other plugins to quit unexpectedly.
This will likely be the last update before I take this one out of beta. I really mean it this time.
Dave
Mon Dec 19, 2016 7:05 am
WUnderstation Plugin v1.0.01 is now available
  • Moves the project to GitHub and increments the version number. There is no new functionality in this update.
Fri Jan 06, 2017 12:47 pm
WUnderstation Plugin v1.0.02 is now available
  • Adds WUnderstation device type.
  • Moves support URL to Github.
Mon Mar 06, 2017 9:00 am
WUnderstation Plugin v1.0.03 is now available
  • Reinstates None as a data element option.
  • Fixes errant text in WUnderstation device configuration menu.
  • Fixes bug in weather data configuration menu that caused Outdoor Temperature 1 to be visible all the time.
  • Fixes references to plugin in debug output (cut/paste error).
Sun Oct 22, 2017 12:02 pm
WUnderstation Plugin v1.0.05 is now available
v1.0.05
  • Code consolidation using DLFramework.
  • Adds note to documentation that the plugin requires Internet access to function.
v1.0.04
  • Stylistic changes to Indigo Plugin Update Checker module.
  • Standardizes plugin menu item styles. Menu items with an ellipsis (...) denote that a dialog box will open. Menu items without an ellipsis denote that the plugin will take immediate action.
Mon Feb 05, 2018 2:31 pm
WUnderstation Plugin v1.0.07 is now available
v1.0.07
  • Updates help link to wiki.
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
v1.0.06
  • Adds attribution to Indigo log when the plugin is initialized.
Wed Jun 13, 2018 5:58 am
WUnderstation Plugin v1.1.01 is now available
IMPORTANT: due to changes in the pricing model for the Weather Underground API, development of the WUnderstation plugin will cease with this release.
I will continue to provide bug fixes, but there will be no further feature development.
  • Plugin now requires Indigo 7.0.
  • Increments Indigo API requirement to 2.0.
  • Improves status reporting for Indigo device health.
  • Moves communication to requests module.
  • Updates docstrings to Sphinx standard.
  • Code refinement
Tue Jul 31, 2018 3:25 pm
The WUnderstation plugin has been removed from the Indigo Plugin Store. This is to avoid confusion because WU is no longer providing API access keys.
For those that may need to re-download the plugin, you can do that via Github.
