LATEST Version 0.3.05 - UK Time corrected
Mon Aug 29, 2016 12:07 pm
Chameleon offline
Hi all
Minor update to correct 'Generated at' time on Departure Boards. It will now display the correct UK Time automatically. If you're set up doesn't include the pytz module it will only display GMT time. You can install pytz using pip2.6 in the usual way in Terminal with the command sudo pip2.6 install pytz but it is standard on most MAC systems.
Download the latest version from here:
https://www.dropbox.com/s/rjf1fp4xayj44t6/iTravel.indigoPlugin.zip?dl=1]
Regards
Mike
