[LOCKED] ALPHA Testers only - download 0.2.08
Sat Aug 27, 2016 6:43 am
Chameleon offline
To investigate the install issues that some of you have had in the last 24 hours I'm releasing this special ALPHA version.
It should be installed according to the following instructions in this post:
http://forums.indigodomo.com/posting.php?mode=edit&f=171&p=122247 - see the last post from me.
This process will:
    Remove all previous versions of iTravel (see earlier in the thread for details of exactly which files to remove)
    Get you to check for certain critical modules (dependencies) and information and, if necessary, install them on your system if they are missing
On installing version 0.2.08 (link contained in the forum link above) it will now:
    Check your current system for standard and special python modules and classes
    Ensure your system path is correctly set up to run iTravel now and in the future
    Perform a number of checks automatically and display the results in the indigo log. Please send this to me if you're reporting any issues.
You should then ensure that debugging is switched off in the configuration dialog (Plugins/iTravel/Configuration...) unless you want lots of meaningless data in your log :-)
Thanks again for all your patience - we're getting there... (This is nothing compared to iFindstuff ALPHA!)
Regards
Mike
