0.5 degree temperature increment
Tue Jan 08, 2019 8:39 pm
bsp9493 offline
Love the plugin!!
Question, I control my devices in degrees Celsius...
is there a way (either in the plugin, or in the code) that I can make a change such that when I press the temp up (or down) arrow I get a temp change of 0.5 degrees?
I am referring to using the native thermostat control in the indigotouch iPhone app, currently pressing the red or blue arrow gives a full 1 degree of temp change.
Thank in advance
d
Fri Jan 11, 2019 7:58 am
Re: 0.5 degree temperature increment
I'm afraid that one always adjusts in 1 degree increments. You can assign an action to a custom Control Page button that increments/decrements 0.5 degrees, but the native thermostat UI isn't currently adjustable. Improving it is on the feature request list.
Fri Jan 11, 2019 8:52 am
Switch to F , then u don’t need 0.5
