state key humidityInput1 not defined recurring error
Posted:
Tue Dec 19, 2017 12:45 pm
by Colorado4Wheeler
Is there any resolution to this yet? I figured I would ask before I start rewriting the plugin
- Code: Select all
Error device "Upstairs Thermostat" state key humidityInput1 not defined (ignoring update request)
Error device "Upstairs Thermostat" state key humidityInputsAll not defined (ignoring update request)
Dec 19, 2017 at 11:41:34 AM
Dec 19, 2017 at 11:42:36 AM
Dec 19, 2017 at 11:43:38 AM
Re: state key humidityInput1 not defined recurring error
Posted:
Tue Dec 19, 2017 5:01 pm
by matt (support)
I haven't looked at the Nest Plugin source but from Indigo's perspective that error occurs if the plugin tries to update those states but the plugin device property
NumHumidityInputs is either not defined or 0 (versus 1). Not sure if that helps you.
Posted:
Tue Dec 19, 2017 5:30 pm
by Colorado4Wheeler
Thanks Matt, I knew what was causing it and why I just didn't know if there was a fix for it other than me going in and farting with the plugin. Has the plugin been abandoned? Should I pick it up?
Posted:
Wed Dec 20, 2017 5:07 pm
by matt (support)
Chameleon (Mike) hasn't been around on the forums in several months. He was gone for a long while then
briefly reappeared, but hasn't been back since then. We've reached out to him off forum but haven't been able to get in touch with him. We are all hoping he is doing okay.
Given his absence if you would like to take a look at the plugin that would be great. I am very doubtful he would mind if someone were to make improvements while he is absent from participating.
Posted:
Wed Dec 20, 2017 5:37 pm
by Colorado4Wheeler
matt (support) wrote:We are all hoping he is doing okay.
Amen and amen! I know he dealt with some illness earlier and I hope that is still at bay. I'll pickup the slack and poke around the plugin, my messages have mysteriously disappeared for now but I'll keep an eye on the forum for any issues and beef up on the NEST api.
Posted:
Thu Jan 04, 2018 4:22 pm
by alang_94526
Did you already resolve this? I just added a Nest Gen 3 to my Nest Gen 2 and now I suddenly get this error too. Not sure if is related to going from 1 Nest to 2, or that the new one is in a different property, or and artifact of mixing a Gen 2 with a Gen 3 in the plugin.
I had been running 2.0.32 but upgraded to 2.0.50 with no difference observed.
Posted:
Thu Jan 04, 2018 5:48 pm
by Colorado4Wheeler
Mine went away after a day, I think it may need time to download new data from the API. I am however keeping an eye on it and plan to try to pick up the plugin if needed while Chameleon is tending to his health.
Posted:
Mon Jan 08, 2018 11:48 am
by alang_94526
You were right. It cleared itself presumably for the reason you cited.
Thanks for the feedback.
Posted:
Sun Feb 18, 2018 9:16 pm
by sparker
I've been seeing this since I installed my new Nest about 3 weeks back. Every minute of every day.
Is there some way for me to force the update to the Nest that might make this go away?
Steve
Posted:
Sun Feb 18, 2018 9:24 pm
by Colorado4Wheeler
I’m not sure exactly what makes that error go away but it’s on my todo list to fork the plugin and dissect it.
Posted:
Fri Jun 08, 2018 7:17 am
by vtmikel
Did this disappear for you? When my thermostats were re-created randomly, I experienced the humidity error until I reset the plugin. Then, it stopped.
Posted:
Fri Jun 08, 2018 7:28 am
by Colorado4Wheeler
Yes, it went away on its own.
Posted:
Fri Jun 29, 2018 8:05 pm
by chrisfromthelc
I just installed a Nest E (got rid of the garbage Lyric Thermostat), and am getting this error as well.
edit: And then out of nowhere, it stopped throwing the error.
Posted:
Wed Feb 19, 2020 1:31 pm
by bsp9493
Strange, I am NOT seeing any specific errors, but out of the blue, my NEST devices have quit reflecting the accurate humidity values.
ie, NEST thermostats show 34 and 37 respectively. NEST device in indigo is showing 40 for both. Pressing refresh, restarting plugin, restarting Indigo server, does not seem to resolve.
Is there something else I can try to get the NEST thermostat, and indigo device back in sync?
Thanx in advance
dave
Posted:
Thu Feb 20, 2020 8:48 am
by dduff617
Just a data point, FWIW: I have two Nests and use Grafana plugin to chart values. I can report that my Nests are reporting humidity changes in what looks to be pretty normal fashion over the last few months (that is with the usual 5% granularity).
